Old 07-12-2020, 12:03 PM   #1
2015 30' Flying Cloud
Port Sanilac , Michigan
Shower door stuck
The shower door on my FC30 is hanging up at the bottom of the door where it is scraping the bottom door sill. I have long since lost the rubber seal so it’s metal on metal. The door is not loose on the hinge side but seems to have lowere itself a bit vertically. I can grab it and lift it about 1/8 “ straight up to get it open/closed. Any thoughts?
pontzdav is offline   Reply With Quote
Old 07-16-2020, 02:18 PM   #2
I found the problem. The small 6 x 32 machine screw that holds the door frame together at the top of the door sheared off. Replaced screw, all is well.
Old 07-16-2020, 02:21 PM   #3
pic attached
pic attached
Old 07-16-2020, 02:42 PM   #4
Baby Zeppelin's Avatar
2018 28' Flying Cloud
Clayton , Georgia
I have the symptoms you describe, but I'm not sure I have the same cause, as screws appear to still be in place. I ended up going to the hardware store and buying a nylon spacer 3/4" in diameter and 3/8" thick. Put it under the door's pivot point in the channel at the base of the door opening. That raised the door enough to correct the problem.
As long as my wife is happy with it I'm happy with it.
Erik & Carol
Clayton, Georgia
AS: 2018 Flying Cloud 28 "Baby Zeppelin"
TV: 2017 Ford F250 Lariat w/ Blue Ox Sway Pro
AIRForums #126944 WBCCI #1297
Baby Zeppelin is offline   Reply With Quote
Old 07-17-2020, 07:08 PM   #5
Screw was in place but broken
My screw was in place as well. But it was broken. Tried to tighten. Nothing. Turned out the 1.5 inch screw was broken about a half inch from the head
Old 07-17-2020, 08:33 PM   #6
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Shower door stuck
Recommend you support from below. Common fix for relieving stress on that upper screw / hinge assembly.
Here is the kit airstream will send you free of charge if you give customer service a call....
https://www.airforums.com/forums/f54...ng-200978.html
wulfraat is offline   Reply With Quote
Old 09-19-2024, 10:19 AM   #7
2016 28' Pendleton
terre haute , Indiana
My fix
We had this problem and I tried everything to fix it. I got a hold of the manufacturer and they sent me some new parts and I completely rebuilt the door. It lasted a while. I tried every possible shim. I bought a cutting board and cut it into different shapes. The sweep at the bottom wouldn’t last at all. Finally took the three screws out of the jam side, raised the whole jam about 3/8 of an inch, drilled three new holes and secured with the screws. Took about 10 minutes. Knock on wood, but it’s been perfect ever since.
jcwall is offline   Reply With Quote
Old 09-20-2024, 10:36 AM   #8
JeffKim's Avatar
2023 25' Globetrotter
2021 16' Bambi
Forest Lake , Minnesota
When we were at JC they installed this fix. We hate it. It requires lifting the shower door by the edge to open and close which is not so easy when inside the shower. I don't know of anything better, but seems like they should have figured out a way so the sagging doesn't happen, this is more or less a kludge.
2023 Globetrotter 25FBT "Curly"
2017 Audi Q7 3.0T
WBCCI 6343
JeffKim is offline   Reply With Quote
Shower Curtain or Shower Door for 1972? mello mike Sinks, Showers & Toilets 27 10-02-2022 06:12 PM
stuck tambour door airbrushgal Cabinets, Counter Tops & Furnishings 28 06-05-2021 04:58 PM
Outdoor Shower Lock STUCK GoinStreamin Exterior Storage Compartments & Access Doors 14 05-27-2021 12:56 PM
Stuck Moen shower cartridge flyingfishy Sinks, Showers & Toilets 25 02-02-2021 05:57 PM
Has anyone had a custom lucite or clear plastic folding shower door made fro shower? Driftin Di Sinks, Showers & Toilets 2 08-09-2017 07:34 AM
