Old 06-16-2023, 11:01 AM   #1
2014 25' International
Hampshire , Illinois
Shower Door sliding down
Hello, we own a 25’ International Signature 2014. Own glass shower door slid down and gets stuck in the lower shower door frame. I tried propping it up with a spacer under the end of the hinge side but that seems to work for a small amount of time. Has anyone else had this problem? Does anyone know a fix to this problem?
Sincerely, Tom and Debbie Moquin
debfm is offline   Reply With Quote
Old 06-16-2023, 03:47 PM   #2
2002 19' Bambi
Lafayette , California
There are many posts about similar shower door problems:
https://www.airforums.com/forums/f16...ue-123619.html
https://www.airforums.com/forums/f44...ir-214321.html
https://www.airforums.com/forums/f16...or-159112.html
https://www.airforums.com/forums/f45...ck-211117.html
https://www.airforums.com/forums/f44...er-215729.html
Tim
Tim A. is offline   Reply With Quote
Old 06-16-2023, 03:58 PM   #3
Castaway's Avatar
2012 25' FB Flying Cloud
Celina , Ohio
Use silicone to hold the spacer in place
Castaway is offline   Reply With Quote
Old 09-19-2024, 10:18 AM   #4
2016 28' Pendleton
terre haute , Indiana
New fix
We had this problem and I tried everything to fix it. I got a hold of the manufacturer and they sent me some new parts and I completely rebuilt the door. It lasted a while. I tried every possible shim. I bought a cutting board and cut it into different shapes. The sweep at the bottom wouldn’t last at all. Finally took the three screws out of the jam side, raised the whole jam about 3/8 of an inch, drilled three new holes and secured with the screws. Took about 10 minutes. Knock on wood, but it’s been perfect ever since.
jcwall is offline   Reply With Quote
2016 AI sliding screen and sliding door biboutside Sprinter and B-van Forum 2 05-27-2020 06:23 AM
Interstate Sliding Door / Side Door Lock Jammed Pondiki Sprinter and B-van Forum 14 11-15-2018 11:15 AM
Sliding Shower Door on 1970 23' Safari rucos Interior Restoration Forum 11 09-13-2015 11:51 AM
Goin' down, down, down... Aironius Axles 12 08-23-2014 08:09 AM
Sliding screen door for the sliding door! weirdstuff Sprinter and B-van Forum 29 02-28-2014 08:19 PM
