short rough-in toilets
Our 2011 27FB has the AquaMagic V with the 7 5/8 rough in. We have around an inch of extra space behind the toilet. It's been used, maybe abused, and it's in need of replacement.
Contenders
AquaMagic V - 7 5/8 rough in. does it still have the cavity or did anyone in that company brighten up and put in a pipe?
AguaMagic VI - 7 5/8 rough in. Same as V, but maybe it has a pipe?
Dometic 300 - 8 1/2 rough in. Did they address the leakage issue that caused oders, or is that still a problem with new units?
Dometic 310 - 10" rough in. I have to remove the wall to fit it, otherwise I'd probably to with this.
Aqua Magic Style II - 9 1/2 rough in. I'm on the fence about it fiting, I don't think it will, which would require removing the wall. If it were 9" I might be able to force it.
* removing the wall starts down the path of a remodel, which I'd rather not get into.
Are there any other options, or is this really just it, just two companies. Not into composting toilets.
