Old 04-05-2024, 07:01 PM   #1
TrvlTin
TrvlngTinTin's Avatar
2023 30' Globetrotter
Boulder , Colorado
Shattered shower door help!
Just left home base to get over vail pass before snow storm.
I had tires set at 80 which is higher than I normally keep them usually around 75 with the heat today. I think they were around 83 not sure if it was what caused the shatter? Or I did store foam mattress for tent camping? But leaning towards the outside? Might have flapped inward?
Any how anyone now if this can be repaired on the road trip.
Or recommend shower curtain till I get home?
Hoping someone dealt with this before me it might be able to help thank you!
Todd
ID:	442512   Click image for larger version
TrvlngTinTin is offline   Reply With Quote
Old 04-05-2024, 09:23 PM   #2
airstreambob's Avatar
2019 25' Flying Cloud
1992 21' Sovereign
2000 30' Excella
2001 31' Land Yacht
Valley Park , Missouri
Images: 13
Quick solution for broken glass shower door
A 1/4-3/8 diameter spring curtain rod with the little rubber cups on the ends in the appropriate length will span the slots that the door itself sat in after removing the door frame that held the glass. A 36" wide shower curtain with rings completes the install. It will be a little long, so you can cut it if you want. Do not remove the parts of the shower door framework that attach to the left and right sides.
When you want to replace the door from Airstream, the door only is sold as a complete unit, including the parts you will leave in until you are ready to replace. The Door assembly is over $400 plus shipping.
A number of owners have taken the glass portion of the door out on purpose, as a curtain gives a bit more elbow room that a sheet of glass when in the shower.
airstreambob is offline   Reply With Quote
Old 04-05-2024, 09:55 PM   #3
TrvlTin
Boulder , Colorado
Thank You! For the information! And Help!
Will be shopping for curtain rod soon��
Old 04-05-2024, 09:56 PM   #4
1992 21' Sovereign
2000 30' Excella
2001 31' Land Yacht
Images: 13
Shower curtain photo
Check my images for a photo
Old 04-06-2024, 09:20 AM   #5
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
What caused it? Who knows ....
Door not latched when you took off and it flopped back and forth? Ok, but ... is it latched now? Latching after it breaks seems like a really strange thing to have happen.
Stored items hit the door and nuked it? Ok, but .... just how heavy *is* that stuff? The blue + gray foam pad weighs next to nothing and it's pretty low. The bigger (foam?) is up a bit higher and it might actually weigh something. Still weird that the both are sitting away from the door and not tangled up in broken glass.
The shower door doesn't have a lot of "flex". All you have to do is push the wrong way and you can shatter it. ( = glass does not bend easily ....).
Another thing to put on the list: Is the door mount still correct? Did the hinges slip and allow the door to get to tight in the opening? That plus a pretty minor amount of chassis flex going over a pothole .... yup you have glass all over the place. Ok, so maybe they fixed all the potholes since I was last there .... I sort of doubt it
Crazy !!
Old 04-06-2024, 10:04 AM   #6
2001 30' Classic S/O
Lady's Island , South Carolina
Shower door
Not a quick fix, but I highly recommend this product be considered for a long term solution.
https://shop.stoett.com/product/nautilus-shower-door/
Lighter weight, does not fly open when least expected -or wanted, does not break😁, squeegees water off into the shower (rather than drip on the floor).
I fought the shower door blues for a long time until a friend showed me his installation.
Easy to do.
Tip, when ordering, leave 3-4” open at top for steam/moisture to get out.
Quite possibly the best mod I’ve done yet.
Just sayin’
booma is offline   Reply With Quote
Old 04-06-2024, 10:50 AM   #7
2023 27' Globetrotter
Williamsburg , Virginia
If your tires are GYE, 75 lbs might be a little stiff...I think you could safely run them lower (mine are 65 psi cold on GYE with a GT 27. Hard to know if this was the contributing factor, however.
AgBullet is offline   Reply With Quote
Old 04-06-2024, 12:19 PM   #8
2019 25' International
Washington , Washington, D.C.
The shower door shimmies even with its little latch closed i.e. with latch in place, you can push against the door and feel back and forth movement. Driving on washboarded roads or uneven, undulating pavement can set that door reverberating itself into pieces.
A fellow Airstreamer gave me the clip shown in photo to place at the top of the shower door. He showed me how to ensure - that when clipped correctly into place - that there was NO movement in the door. I think this tip stood me in good stead during my Alaska trip last summer.
See photo.
PatLee is offline   Reply With Quote
Old 04-06-2024, 01:10 PM   #9
Taroni's Avatar
2016 25' Flying Cloud
Lake Jackson , Texas
Do not replace with Airstream door.
https://shop.stoett.com/product/nautilus-shower-door/.
My screw broke at the top. $600.00 for Airstream Replacement, which might last a few years and break again. Or buy this one that is much lighter.
Tom Taroni
Taroni is offline   Reply With Quote
Old 04-07-2024, 06:09 AM   #10
Bluffton , South Carolina
Easy to do.
Just sayin’
Hi Booma
We’re considering replacing our shower door and have been looking at this type replacement. How long have you had your Stoett and did you have any issues with installation? Thanks
69SoulShine is offline   Reply With Quote
Old 04-07-2024, 10:47 AM   #11
JeffKim's Avatar
2023 25' Globetrotter
2021 16' Bambi
Forest Lake , Minnesota
No help immediately but definitely make a warranty claim. With our 2023 we ran over a curb and our bathroom mirror hit the ceiling and broke. AS is replacing it under warranty. It is definitely worth a try with your shower door.
2023 Globetrotter 25FBT "Curly"
2017 Audi Q7 3.0T
WBCCI 6343
JeffKim is offline   Reply With Quote
Old 04-07-2024, 11:56 AM   #12
2002 19' Bambi
Lafayette , California
Our 2002 19' came with a "door" almost identical with the present Stoett versions. It has worked perfectly since we bought the trailer new. The original caulking along the bottom of the lower guide cracked and leaked. We re-caulked several times until using Sikaflex and that has held ever since. Sikaflex is not a common caulk for showers, but, unlike conventional shower caulk, it remains flexible and adheres very well. Silicone caulk also failed in the same location.
Tim
Tim A. is offline   Reply With Quote
Old 04-07-2024, 01:13 PM   #13
9 months now. Love it easy peasy install.
Toughest part for me was the caulking inside and out.
Best single upgrade yet for us��
Old 04-10-2024, 09:16 AM   #14
dvgofaz's Avatar
2005 34' Classic
tucson , Arizona
I second the others who recommend the 'window shade' type of door. I think mine was under $200 and it works great and took 10lbs of glass away.
dvgofaz is offline   Reply With Quote
Old 04-10-2024, 09:33 AM   #15
2023 33' Classic
Chandler , Arizona
Yikes, storing anything in the shower is a no go, especially if it is capable of falling against the shower door. Bumpy roads with anything falling against the shower door, could have been the cause.
Saullman is offline   Reply With Quote
Old 04-10-2024, 09:49 AM   #16
prostar's Avatar
2020 27' Flying Cloud
Allen , Texas
A friend went to Home Depot and replaced glass with plexiglass. He said it was easy to do.
prostar is offline   Reply With Quote
Old 04-10-2024, 10:02 AM   #17
2012 30' International
no man is an island , Oklahoma
Ours did not shatter, just fell apart. We are going to try stoett nautilus. 3 week delivery.
Shower curtain in the meantime.
D.l.briggs is offline   Reply With Quote
Old 04-10-2024, 10:16 AM   #18
Bearstream01's Avatar
Garden City , New York
Please let us know how installation goes! I want to do this too!
2023 Airstream International 25RBT
2019 F250 XLT 6.7L Power Stroke Diesel
14457
Bearstream01 is offline   Reply With Quote
Old 04-10-2024, 10:20 AM   #19
2014 25' FB Flying Cloud
Chicago , Illinois
try Shower Enclosures of America
We had to replace the hinge-side frame on ours but not the glass. No catastrophe, just wore out. We got a good price and excellent service from Shower Closures of America. They might be another option for you.
https://www.seamerica.com
But if we had to replace the glass, I think I'd go with the lightweight replacement.
janicemd is offline   Reply With Quote
Old 04-10-2024, 10:35 AM   #20
2008 22' Safari
Acrylic and Plexiglas sheets are sold at Home Depot and not difficult to cut and replace with common tools
Shattered shower door Ultragary Sinks, Showers & Toilets 3 07-11-2023 10:14 PM
Rear Cargo Door Glass Shattered JDub802 Base Camp 1 04-23-2021 02:33 PM
'69 Globetrotter with shattered window. Help!! montanablue Windows & Screens 8 06-26-2011 06:58 AM
Shattered window Tin Can Windows & Screens 16 02-13-2006 07:27 PM
SHATTERED FRONT RT CURVED WINDOW RREGESTER Windows & Screens 5 02-22-2003 08:25 PM
