06-30-2022, 08:43 PM
2022 28' Flying Cloud
GAINESVILLE
, GA
Second Container For Second Stinky Slinky
Where can I get a second stinky slinky container? I think it will fit nicely under the rear bumper.
Thanks.
06-30-2022, 08:50 PM
2017 22' Sport
Raleigh
, North Carolina
I use the optional bumper with the storage compartment. And keep the backup in the original tube. Bumper has room for the elbow and a box of nitrile gloves. I can grab a photo if needed!
06-30-2022, 09:55 PM
2016 20' Flying Cloud
Manhattan
, Kansas
Amazon, Camping World, and most RV suppliers have them.
Have you checked for clearance under the bumper? My AS is shorter than yours, but I think it might be a bit vulnerable in that location.
Pete
07-01-2022, 10:26 AM
GAINESVILLE
, GA
Pete
We have a 3” Dexter Lift Kit, so that will help. Thanks for pointing me in the right direction.
By the way, do you know the manufacturer of the one that comes with AS?
Thanks again.
07-02-2022, 07:24 AM
GAINESVILLE
, GA
Thanks guys for pointing me in the right direction.
I looked a little closer at the AS slinky container and found it was made by Valterra in Mexico (better than China). I purchased a Valterra A04-3460BK that extends from 34 to 60 inches, hence the “3460” designation.
I was going to try and make one from some 5” exhaust pipe and clamps, but when I received the clamps, I couldn’t believe how heavy they were, so back they went. The bumper floor is stiff, but, in my opinion, too thin to support the weight of my proposed contraption.
07-02-2022, 04:35 PM
Escape Pod II
2018 22' Sport
2022 23' Flying Cloud
Orange
, TEXAS
I put mine here.
JEWare
07-02-2022, 08:11 PM
2020 23' International
Evergreen
I put two 10-foot collapsible sewer hoses in the factory storage compartment, connected together. No problem.
Dennis
2020 International Serenity 23 FB "Sparkle Plenty"
2018 GMC Sierra Denali 1500
Airstream Club International #2805
07-03-2022, 05:11 AM
1994 25' Excella
Waukesha
, Wisconsin
The answer for us was to get a second storage tube from Amazon and mount it behind the rear axle, about halfway to the back bumper. I wanted it near enough to the axle that it didn't cause any ground clearance issues.
Richard
11018
07-03-2022, 05:43 AM
1993 34' Excella
York
, South Carolina
A straight flush beats a full house.....
Just couldn't resist this one....
I'm anal about my tanks, valves, and dumping procedures. If you have ever found yourself underneath, repairing the valves, you know why taking care of them is so important.
I carry a 5', 10', and 20' hose. The 5 and 10 fit in the rear bumper compartment, the 20 rides in a PVC tube underneath, near the axle.
Which one I use depends on where the sewer outlet in the ground is located in relation to where the trailer is parked. When possible, I park the trailer so the exit pipe is a straight shot to the sewer hole and use the shortest hose to make a "straight flush".
Next time you are out walking in a crowded campground, look at how many folks have a 20' hose snaked around like spaghetti when a 5-footer would be perfect.
A full house......
John
John
WBCCI #268 Palmetto State Airstream Club 22
Region 3 Past President....come with us, you will like it.
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?..... Jerry Garcia
07-03-2022, 06:56 AM
GAINESVILLE
, GA
Originally Posted by John Ware
I put mine here.
Looks good!
I like the location, but how do you mount it, i.e., where does the mounting screws/bolts go through to the top side? I don’t want them going through and hitting an electrical wire or water line, etc.
What kind of screws/bolts do you use?
Thanks.
07-03-2022, 07:57 AM
Escape Pod II
2018 22' Sport
Orange
, TEXAS
I used self tapping screws like AS used but I coated the threads with hot glue. I was prepared to use threaded rivets if the glued screws didn't hold. The original one seems to have some kind of backing plate that it is screwed to. If I have to redo it, I will rivet a strip of aluminum in place to screw the brackets to but no problems so far.
JEWare
