Old 06-27-2023, 08:17 PM   #1
2003 25' Safari
Kissimmee , Florida
Replacement for Moen Puretouch Classic faucet
This faucet hasn’t been made in years, and the filters are expensive and hard to find. One of the copper inlet pipes on mine cracked, spraying water all over. I found a non-filtering replacement that uses the single plumbing hole and a side sprayer. It needed two adapters for the inlet pipes, but otherwise was a clean install. Here are the replacement parts from Lowe’s:
Moen Torrence faucet with sprayer 230645
2 Brass fittings 3/8 compression to 1/2 MIP 877149
It was difficult to remove the old faucet, I had to cut off the attaching nut with a Dremel.
I hope this helps someone.
dmac is offline   Reply With Quote
Leaking PureTouch Classic Kitchen Faucet StreaminGeo Sinks, Showers & Toilets 2 08-05-2023 09:57 AM
Moen Kitchen Faucet ahead replacement Techfan70 General Repair Forum 3 08-31-2019 10:57 PM
Moen PureTouch Galley Faucet nickmeloy Sinks, Showers & Toilets 6 10-27-2014 07:15 AM
Moen faucet replacement sieve Waste Systems, Tanks & Totes 18 11-25-2012 08:11 PM
Moen Puretouch Galley Faucet BoJo Fresh Water Systems 5 03-01-2009 06:44 AM
