Old 05-14-2024, 08:12 PM   #1
2020 16' Caravel
Salt Lake City , Utah
Replace shower faucet in 16RB
I would like to replace the faucet for the shower in our 2021 16RB Caravel. Has anyone done this. I know where to get a new faucet but I'm not sure how I would access the back side to unhook the prior one and connect the new one. I know there is an access area on the back wall under the mattress area but I'm not sure I can reach to that are from there.
lisaapple is offline   Reply With Quote
Old 05-14-2024, 09:30 PM   #2
Piggy Bank's Avatar
2019 27' Flying Cloud
Kansas City , Missouri
If you go onto the airstream dot com website, you can download the parts diagram for your trailer. This makes it nice to see how everything fits together.
Go to Owners, and then Manuals and Parts Books.
FYI if you go to Owners, and then Resources and Owner's Hub, you will find more info as well.
Piggy Bank
Piggy Bank is offline   Reply With Quote
Old 05-19-2024, 11:16 PM   #3
2014 16' Sport
San Jose , California
It is tight, but if you remove the first bed board, you can reach the couplings and unscrew to remove/replace with a new faucet. The center/shower supply cracked and and I’ve ordered the faucet and couplers to swap. (Apologies for the photo being upside down-kept uploading that way)
dennarr is offline   Reply With Quote
Old 05-26-2024, 04:57 PM   #4
2014 16' Sport
Wooho!
Got my leaky faucet replaced. Tip: unfasten the shower connection (in the hamper) to make screwing the faucet out line easier. Was a bugger trying to attach…kept going on crooked.
Old 06-03-2024, 09:54 PM   #5
2020 16' Caravel
Success! thermostatic faucet installed easily. No major tools needed other than a plumbers wrench. Extra purchases needed were a 79 inch shower hose (the attachment is slightly lower so the hose has to be longer) and a sink hole cover for the middle hole which is no longer used. Thanks for the help everyone!
Seems to work perfect (no cold blast)....will see if it lasts.
L
ID:	443971   Click image for larger version
Old 06-04-2024, 07:38 AM   #6
2018 16' Sport
Tacoma , Washington
Lisaapple -
Can you tell us the purchasing info (make, model number, cost, where purchased, etc) of the faucet and hose you installed?
2011 Ford Explorer Limited with factory tow package
2011 Harley-Davidson Ultra Limited
Runamuk13 is offline   Reply With Quote
A closet shelving system for Caravel 16RB or Bambi 16RB hovr Cabinets, Counter Tops & Furnishings 26 05-28-2024 09:59 AM
2021 Bambi 16RB - Hot Water shower issues ricko24 Fresh Water Systems 13 03-18-2021 02:07 PM
Newbe 16RB shower JeffDavis Member Introductions 4 07-12-2019 07:03 PM
Replace shower faucet in Sylvia/Larry? david b jone Sinks, Showers & Toilets 3 04-24-2007 07:14 AM
