Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 10-01-2009, 06:08 PM   #1
2000 31' Excella
Maryville , Tennessee
Paint peeling in sink.
Just got this 2000 excella and noticed a few small chips in the painted white sink. Any ideas how to fix this ?
I don't think this sink is enamel.
Is there a paint I can use to repaint it ?
Robbie R.
Robbie R. is offline   Reply With Quote
Old 10-01-2009, 06:18 PM   #2
pbearsailor's Avatar
Port Hadlock , Washington
Maybe this: POR-15 Whitecote 2-Part Paint (One Pint)
Haven't used it, but their rust coating I've used on the frame and it's fantastic.
Forum Thread: First She Had to Take a Ride on a Boat
Blog: My 57 Caravanner
pbearsailor is offline   Reply With Quote
Old 10-01-2009, 06:29 PM   #3
2000 31' Excella
Thank you. That could be a solution.
Robbie R.
Old 01-02-2010, 09:46 PM   #4
moderator
Airslide's Avatar
2016 27' International
Wilton , California
Images: 50
My sink is peeling too. I thought about painting it or removing it and having it done..
I just decided to purchase a new stainless steel sink and be done with it. I do like the white but the stainless will be more durable and with the sink covers over it when not in use its fine for us. It was a little tricky to remove it as there are retainers on the underside and the sink is bonded to the underside of the corian counters with silicone. It was a very slow process removing it. Pictures when finished.
Vinnie
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 01-03-2010, 09:26 AM   #5
2000 31' Excella
Thanks for posting this. I would love to see pics when your done.
Robbie R.
Old 01-03-2010, 03:44 PM   #6
Cracker's Avatar
Pittsfield , Maine
They must have had a bad batch of sinks around 2000 since my 2000 30' Excella has the same problem. I would also appreciate a "show and tell" on just how easy/hard it is to replace the sink with a stainless one. For now, I place a rubber protector in the bottom of the sink to hide the missing paint.
Cracker
2003 GMC 3500 D/A, CC, LB, 4x4 and 2000 Airstream Excella 30. WBCCI 7074
Cracker is offline   Reply With Quote
Old 01-03-2010, 04:25 PM   #7
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Mine looked like a chip out from dropping something, a dab of 5200 was a good temp fix, was in a place that a plastic sink protector now covers it.
DaveFL is offline   Reply With Quote
Old 01-03-2010, 04:32 PM   #8
moderator
Airslide's Avatar
Wilton , California
Images: 50
Look familiar??
Hi guys,
I dont have the sink installed yet (pictures to follow) but I did remove the old one and took a few shots showing how its attached. I was very careful removing it as you have to pry carefully from underneath and cut away the silicone as you put more downward pressure on the sink. I was afraid I was going to break the corian counter top. But just be patient and it comes lose.
ID:	93450   Click image for larger version
Old 01-03-2010, 04:36 PM   #9
Dwight's Avatar
1999 34' Excella
Joshua , Texas
Does your S/S sink fit the existing hole or will you have to alter it? I would be interested in the brand and model number of your new sink.
I have the same sink with a small chip and have thought about have one of those companies that redos your bath tubs with epoxy.
History doesn't repeat itself, people do!
Dwight is offline   Reply With Quote
Old 01-03-2010, 04:58 PM   #10
moderator
Airslide's Avatar
Wilton , California
Images: 50
The sink is an RV size of 27" x 16" x 6" deep. I havent recieved it yet but should be a perfect fit without any modifications.
Vinnie
Old 01-04-2010, 11:28 AM   #11
Cracker's Avatar
Pittsfield , Maine
Vinnie
Vinnie:
Once you get the sink and check for an exact match please let the rest of us know where you bought it. Also, since this problem seems to occur in a limited number of model years, did you inquire at the mothership to see if they could offer a replacement that didn't have the "peeling" problem?
Cracker
Old 01-04-2010, 05:17 PM   #12
Dwight's Avatar
1999 34' Excella
Joshua , Texas
The hole in my counter measures 31-1/4" x 17-1/4". So far I haven't been able to find an under-counter sink that fits without some extra cutting. Are most of you going back with top-mounting sinks?
Old 01-13-2010, 08:28 PM   #13
moderator
Airslide's Avatar
Wilton , California
Images: 50
The sink has arrived
I installed the sink tonight. It was an exact fit from the sink I pulled out. There was no modification necessary. One problem that I didnt realize.. The drains are only 2" vs the larger ones in the airstream. My wife didnt care so Im good!
Here is the link.. NEW HOME RV STAINLESS STEEL 27 x 16" KITCHEN SINK:eBay Motors (item 370282493079 end time Jan-27-10 13:06:31 PST)
This is a current listing and exact sink I bought. The price is right and it seems sturdier than the one i removed.
ID:	93976   Click image for larger version
Old 01-14-2010, 06:56 AM   #14
2000 31' Excella
Super looking job !
I may measure mine to see if one of the others will fit it.
Robbie R.
Old 01-14-2010, 07:56 AM   #15
moderator
Airslide's Avatar
Wilton , California
Images: 50
Thanks Robbie,
Didnt mean to steal your thread... the job wasnt too bad. I still have to get the correct drains for it but I think that can easily be found at home depot or somewhere like that.
Vinnie
Old 01-14-2010, 08:36 AM   #16
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
Great looking SS sink, looks like what should have been there from the beginning. Why would A/S put in a "painted" sink rather than the white corian style sink to begin with.
Don
adonh is offline   Reply With Quote
Old 01-14-2010, 08:48 AM   #17
StreamNTyme's Avatar
2007 25' Safari FB SE
2000 30' Excella
1999 30' Excella 1000
Low Country , South Carolina
Images: 27
HI Robbie,
We had the same problem with our sink peeling..my husband pealed the rest of the paint off and it was a very nice stainless sink. It cleaned up nicely. I have no idea why they painted the sinks but it looked much nicer after the paint was removed. He had it done in a very short time.
Kate
StreamNTyme
StreamNTyme is offline   Reply With Quote
Old 01-14-2010, 09:41 PM   #18
moderator
Airslide's Avatar
Wilton , California
Images: 50
I too thought about peeling off the paint the rest of the way. I figured I would have to remove it to get it all off so I shopped around and found out the sink is not very expensive and went that route. I dont mind having the stainless look vs the white. Im not sure why they went with the white.. maybe just to make it more elegant..
Vinnie
Paint coming off of sink. Cracker General Interior Topics 4 07-31-2009 10:04 PM
Peeling wallpaper by the kitchen sink casarodante Cabinets, Counter Tops & Furnishings 26 12-22-2008 07:57 AM
Galley Sink Paint Pealing Off Cracker Sinks, Showers & Toilets 1 04-21-2008 05:47 PM
Peeling Paint on steel rims Silverexpress Tires 2 03-28-2008 07:14 PM
Exterior paint peeling! Astrodokk Airstream Motorhome Forums 2 08-10-2003 08:18 PM
