First time out with 2019 FC this year. Hooked to city water. We have water in all faucets except none to commode. Valve on floor behind toilet is open. Any ideas?
Disconnect the water line to the toilet and see if water will flow when the valve is turned on. Maybe the water valve in the toilet was damaged (freeze).
Richard Wally Byam Airstream Club 7513
I agree, it's probably air in the line or bad valve. The valve stem should be inline with the pipe for open, and perpendicular to the pipe means it's closed.
