08-08-2018, 07:28 PM
1964 22' Safari
1993 25' Excella
Flagler Beach
no water in toilet......
have a 1993 classic 25' ... went camping for a few days, wife noticed
no water would stay in the toilet, hmmmmm maybe seal
well... after thinking about this, maybe its time for new one, word has it..
thetford bravura low profile is a direct replacement, but does anyone
have any better ideas ? thx
08-08-2018, 07:33 PM
Rivet Puller
2003 28' Safari S/O
Atlanta Burbs
, Georgia
Changing the gasket is a multi-minute, low cost endeavor. A toilet swap is considerably more time and expense. However, a bride may prefer a ceramic bowl over plastic.
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
08-08-2018, 07:36 PM
1964 22' Safari
1993 25' Excella
Flagler Beach
hmmmmm
to replace seal at the flapper , guess I still have pull toilet ?
08-08-2018, 08:25 PM
2019 27' Globetrotter
Missouri Valley
, Iowa
If you have time you could try what I did with my '89 Excella when the bowl wouldn't hold water. I added cooking oil and let it sit in the bowl to soften the seal. It worked - but I did it over the winter. But, hey, it's cheap and may work. Give it a shot !!
Dan
08-09-2018, 03:16 AM
2000 25' Safari
Davidson County
, NC Highlands County, FL
I replaced the flapper seal in my 99 Excella. It took me a few hours, but could be done faster. I bought a rebuild kit at ODM that had every thing that is needed. Yes, the toilet has to come out.
Alan
08-09-2018, 05:56 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Dan
X2
I always add it for Winter storage.
NEVER RV antifreeze. Especially the cheep stuff.
08-09-2018, 10:31 AM
2014 25' International
Roanoke
, Virginia
Try this before you do all that replacing
I had a similar problem in our Airstream. I tried this product Thetford RV Drain Valve Lubricant 15843, 24 oz. Bottle and it fixed it right up.
08-09-2018, 11:16 AM
1964 22' Safari
1993 25' Excella
Flagler Beach
will try that.......if it works great, if not, new toilet for 200.00 $$ and little labor
thx ya'll
08-09-2018, 11:17 AM
1964 22' Safari
1993 25' Excella
Flagler Beach
thx...
thx ya'll
08-09-2018, 12:31 PM
1996 34' Excella
Elberta
, Alabama
Dan
Murphy's Oil Soap does a good job also, both on the toilet valve and the back and gray water holding tank valves....
Larry
08-09-2018, 03:25 PM
2017 19' International
Tallahassee
If the toilet bowl isn’t aligned exactly over the flapper, the bowl can leak.
I fixed a leaky bowl by bumping the bowl a bit.
Got it lined up right and ... hasn’t leaked since.
08-09-2018, 06:07 PM
2017 27' International
Galt
no water in toilet
We have been there, a lot! We had a 2001 25' Excella, and the toilet never would hold water from day one. The dealer tried to fix it, and it worked for awhile. they would not replace the unit saying it was a maintenance issue.(stuff can get into the groove where the valve slides in) I made a small
"T" handle clean out tool from some stiff wire, and that worked for that issue.I pulled the whole unit off while camping and found the big seal on the stem had been installed backwards. Fixed that too! After 14 years of misery, I just bought a new toilet. Problem solved. New trailer has a Dometic, and I have had no issues.
