Old 04-13-2021, 11:50 AM   #1
1988 25' Excella
louisburg , Missouri
Need to replace kitchen faucet.
I have a 73 land yatch. 20 feet in length.How do I replace the kitchen faucet? Do I have to remove sink to get to the faucet? If so how do you remove sink?
dtutko1 is offline   Reply With Quote
Old 04-13-2021, 08:23 PM   #2
1969 18' Caravel
Greenville , whereEverIroam
Images: 20
Replacing a kitchen faucet in these trailers is pretty much like replacing any kitchen faucet, only the working space in these RVs is considerably smaller than in a home. If you’ve done it before, there you go, if not, Search YouTube.
Depending on your particular coach, gaining access to the underside of the sink may be challenging. If the nuts are rusty, if your lines are copper, pex or some jury-rigged hose will also impact how easy it is. If it gets too complex, you can always pay a plumber, but most DIYers can do it.
skyguyscott is offline   Reply With Quote
Old 06-03-2023, 08:17 AM   #3
2019 16' Sport
Simpsonville , South Carolina
Replace kitchen faucet
I’m trying to do the same thing, replace the faucet. In the meanwhile I’ve turned off the stop valves and the leak stops!
We have a 16’ Bambi and I thought about removing the sink to get to the faucet. Mine is held down with at least 3 screws (probably 4) with tabs overlapping the counter.
Haven’t tried yet, but will let you know.
Buist is offline   Reply With Quote
Old 06-03-2023, 08:33 AM   #4
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
There are special wrenches to get to the fittings without removing the sink.
Two common styles:
https://www.amazon.com/Installer-NIC...xpY2s9dHJ1ZQ==
https://www.amazon.com/TEKTON-WRN920...s%2C277&sr=8-6
Richard
11018
richard5933 is offline   Reply With Quote
Old 06-04-2023, 05:07 AM   #5
2019 16' Sport
Thanks for the info Richard!
Old 06-04-2023, 05:39 AM   #6
CRH
1995 25' Excella
xxxxx , xxxxxx
I replaced my faucet last month. I took the sink out, which took less than 5 minutes in my trailer.
CRH is offline   Reply With Quote
Old 06-06-2023, 09:14 AM   #7
2019 16' Sport
Replace faucet
We’ll, on mine, removing the sink was more challenging than the faucet; so I didn’t.
The old faucet had 3 screws tapped into the retaining ring at 120 degrees apart. May have been able to use the faucet wrench but was too tight. Taking out the 3 screws and I could spin the retaining ring by hand.
Replace 2006 25 ft Safari SE kitchen faucet HCR Sinks, Showers & Toilets 0 03-13-2021 11:18 AM
Need replacement kitchen faucet for '77 Overlander CPBecker Plumbing - Systems & Fixtures 3 09-02-2019 01:14 PM
Anyone replace the kitchen sink and faucet ? Tronadora Sprinter and B-van Forum 0 02-11-2018 03:40 PM
kitchen faucet leaking Stefrobrts Fresh Water Systems 10 03-16-2004 09:44 AM
Kitchen Faucet Repair niftypkg Sinks, Showers & Toilets 13 09-27-2002 05:02 PM
