12-01-2020, 05:41 PM
2019 19' Flying Cloud
Canyon Country
low water pressure at kitchen sink
I went camping and had water regulator screwed on at water spigot, the water pressure at the kitchen sink was low... water was slow trickled out... I removed the regulator but still same thing.
Anyone think what problem I have with this. The bathroom sink water pressure is good. shower is good. toilet water is good. but not the kitchen sink.... why?
2014 Ford Explorer XLT with factory installed Tow Package.
2019 Flying Cloud 19CBB
12-01-2020, 05:50 PM
2007 30' Classic S/O
Somewhere
, South Carolina
Aerator clogged? Cold and hot or just one?
12-01-2020, 05:55 PM
2013 25' FB Flying Cloud
Longmont
Does your kitchen sink have a separate sprayer? How is the water pressure/flow from it?
12-01-2020, 06:24 PM
1995 25' Excella
xxxxx
, xxxxxx
Another vote for clogged aerator first. However, I had a trickling kitchen faucet before my last trip. My faucet is the kind that pulls out to be a sprayer. I took the sprayer head off and found the aerator fairly clean. Water still trickled with the head off. I used an air hose to blow a little air back in the water line where the head screws on. The water flow was back to normal after that. I guess the faucet cartridge was clogged and the air cleared it.
12-01-2020, 06:46 PM
1972 23' Safari
Middletown
, Rhode Island
Happened to me as well and it was the aerator.
12-01-2020, 07:05 PM
Normal
Aerator and/or the little filter on your water pump.
Maggie
12-01-2020, 10:22 PM
Canyon Country
tried the pump still same weak pressure. yes sink with separate sprayer... ok at my next camping outing, i will check everything you all suggested.
12-02-2020, 04:32 AM
2017 25' International
Niagara-on-the-Lake
, ON Canada
In my trailer, the flexible supply line to the faucet has a shut off valve. Check that as it may have been moved.
Ray B.
12-02-2020, 09:09 AM
2015 27' FB Eddie Bauer
2011 25' FB Flying Cloud
Fernandina Beach
That happened to us a few weeks ago, and it turned out to be the in-line under-sink filter needed replacing. Joe
12-02-2020, 09:11 AM
Married with Airstream
2004 25' International CCD
Vancouver Island
, British Columbia
Aerator clogged - happen to us last spring
La Dolce Vita Brick & Mona
We're Married With Airstream dot com
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD FX4 SuperCrew Lariart (MaxTow) "Red Dragon"
12-02-2020, 10:15 AM
Canyon Country
just kitchen sink only? not personal sink? nevertheless i will check everything. more fun to do that. an excuse for me to go camping alone...
12-02-2020, 09:42 PM
:SPACE A" S/O 11 Air19745
2006 34' Classic S/O
Fort Worth
Most slow flow water problems are caused by clogged aerators, city water inlet screens. or water line debris. I always use a blue inline filter on the city water filter and when filling the fresh water tank. The factory water pressure regulator on the city water inlet is reliable regulator and does not need a separate regulator on the city spigot. That could contribute to lower flow.
guskmg
12-16-2020, 09:39 AM
2017 Interstate Grand Tour Ext
CANON CITY
I have a kinked hot water line in mine. They (airstream ) uses a bend support https://www.google.com/aclk?sa=l&ai=...AUQwg96BAgBEB8 , and the Pex has linked in this support. I still have some flow but it’s restricted. It’s in a area below, and behind the refrigerator area I have bought a shark bite 90 degree fitting. If it collapses to a more restricted form I will have to fix it. So this could be another possibility.
12-17-2020, 03:36 PM
1965 17' Caravel
1983 27' Excella
Walnut Grove/Laguna Woods
Our kitchen pulls out via a hose as many do. Their is a screen in the head as usual, but also a screen where the head connects to the hose. That second screen was plugged on mine.
Don’t know if yours is the same, but could be.
