05-10-2022, 01:14 PM
2021 25' International
Ottumwa
, IA
Leaking toilet flapper
Finally got to dewinterize and all is well except the antifreeze in the toilet was dry and now it won't hold water. Is there a way to restore that? Thanks!
05-10-2022, 01:19 PM
2023 28' International
Mercer County
, New Jersey
They make a product for that:
https://www.amazon.com/Thetford-Toil...002NSU0ZW?th=1
If it doesn't work, replacing the rubber seal is not that difficult.
05-10-2022, 02:24 PM
Ottumwa
, IA
Just ordered it. Thanks!
05-10-2022, 06:39 PM
1993 34' Excella
York
, South Carolina
Pour some vegetable oil in the bowl and work it in with the water turned off.
John
John
WBCCI #268 Palmetto State Airstream Club 22
Region 3 Past President....come with us, you will like it.
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?..... Uncle John's Band
05-10-2022, 07:59 PM
2021 20' Caravel
Plaistow
, New Hampshire
Originally Posted by jeffb831
Appreciate the info.
Learning and enjoying as we go !
05-11-2022, 09:15 PM
2017 25' International
West Lake Hills
The new toilets are shipped with plumbers silicone grease. It is very slick. We tried the Thetford conditioner, to no avail. I'd replace the seal then grease it up.
05-15-2022, 07:33 AM
Ottumwa
, IA
Where do I get a new seal? The stuff I bought didn't work.
05-15-2022, 07:52 AM
Half a Rivet Short
2017 30' Classic
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
Depending on the toilet you have, the usual supply stores can sell you a new seal. Best guess is that the seal is fine. You pull it off the flapper ( being careful not to drop it in the tank ). Once it is off you can see a bit of buildup on the rubber. Once that is removed, re-grease the gasket to flapper joint and the seal area around the flapper to toilet area. That should do the trick.
05-15-2022, 07:56 AM
"Cloudsplitter"
2003 25' Classic
Houstatlantavegas
, Malebolgia
I don't put AF in toilet for that very reason, olive oil, or toilet seal lube only over the Winter.
Others have other opinions but I have found NO RV AF that plays well with the toy seals over time.
Try cleaning the seal with a fairly stiff brush and applying the oil or lube, put enough to cover and let sit overnight.
05-15-2022, 08:21 AM
Mercer County
, New Jersey
https://www.amazon.com/dp/B07P2WQMFD
05-15-2022, 11:15 AM
Ottumwa
, IA
Ordered. Thanks so much.
05-15-2022, 12:17 PM
2018 28' International
Fayetteville
I buy on Amazon.
brick
2018 International Serenity
Cute wife...
05-18-2022, 08:21 AM
Ottumwa
, IA
Took 5 min to replace and holds water great. Thanks.
05-25-2022, 09:36 AM
2013 20' Flying Cloud
2014 16' Sport
2019 23' Flying Cloud
Dunedin
John
What John said! I was just going to tell you the same thing. Lesson learned from him.
“I haven’t been everywhere, but it’s on my list”.
Rosalita WBCCI #12814
Florida Unit #027, Southeastern Camping Unit #012, Florida Suncoast #129, Stella's Sisters, Grapes & Grains, Indie Streamers Save
05-25-2022, 10:02 AM
2019 23' International
Portland
I had his problem on my 2019. It went to the dealer several times because the seal wouldn’t seat. Ultimately they replaced the entire toilet.
2019 International Signature 23FB "Cecil"
2020 RAM 1500 Laramie
Former coach: 2015 Bambi 16 "Beanie"
05-28-2022, 02:24 PM
West Lake Hills
I couldn't get the seal on my toilet to set properly even after trying all the recommendations noted here. It was worth the cost of a new toilet to start fresh. Two were shipped from Amazon; both damaged. However, I was able to cannibalize parts to get one fully operational toilet. I sent the damaged one back to Amazon. Installation was very easy. I suspect that the previous owner may have damaged the plastic flapper, which cannot be replaced.
