Old 03-20-2021, 12:52 PM   #1
StreaminGeo's Avatar
2004 25' Safari
Hanford , California
Leaking PureTouch Classic Kitchen Faucet
I have a Moen PureTouch Classic kitchen faucet in a 2004 Safari. It has developed a leak at the point indicated by the arrow. I’m trying to fix it and have dismantled the faucet pretty much from the top. I’m hoping that someone could give me some pointers before I proceed further. If you can, thanks!
Name:	AS Faucet with Arrow.jpg
StreaminGeo is offline   Reply With Quote
Old 08-05-2023, 06:43 AM   #2
JTD1976's Avatar
Oakville , Ontario
Hello Streamingeo, I found this thread and not sure how old it is. Have a 2005 Safari w the same issue, how did you resolve? Tks so much!!!!! Josh
JTD1976 is offline   Reply With Quote
Old 08-05-2023, 09:57 AM   #3
2004 25' Safari
Hi Josh. I ended up replacing the entire faucet. The Moen was clunky and the handle kept falling off (due to faulty installation I later discovered). The only problem with the process was that since 2004 they changed the hose size from 3/8 inch to 1/2 inch, so I had to use an adapter. The hose I got was too long, but I just looped it around once and it doesn’t affect the water flow. By replacing we lost use of the spray nozzle, but we rarely used it anyway. The replacement faucet is pretty cheap plastic; I’ll get around to replacing it with a more sturdy metal one eventually. The attached pictures should tell the whole tale. I hope this helps!
ID:	435037   Click image for larger version
ID:	435039   Click image for larger version
ID:	435041   Click image for larger version
Moen PureTouch Galley Faucet nickmeloy Sinks, Showers & Toilets 6 10-27-2014 07:15 AM
71 Kitchen Faucet Leaking Lumatic Sinks, Showers & Toilets 8 08-12-2009 08:44 AM
Moen Puretouch Galley Faucet BoJo Fresh Water Systems 5 03-01-2009 06:44 AM
Leaking kitchen faucet 99Limited34 Plumbing - Systems & Fixtures 4 10-17-2008 10:35 AM
kitchen faucet leaking Stefrobrts Fresh Water Systems 10 03-16-2004 09:44 AM
