Old 02-25-2020, 04:22 PM   #1
2018 28' International
Leaking Faucet / / going down to radiator
hey guys-
am out in big bend national park and of course my faucet started leaking and not only that, its going down underneath my 28' FB sink, straight onto the radiator. problem city.
first of all, not sure why AS would put the radiator with open electrical circuitry directly below the sink. stupid.
secondly, my plumbing skills are limited, the faucet only links when I am running the water which indicates that its where it connects to the faucet up under the fixture, not on the connection part.
I should, in theory be able to pull it apart. fix it. but I am concerned real damage was done to radiator, because it started making electrical pulsing noises, almost like repeating whirring clicking noises .
its 100% the radiator from the water, 100% sure about that.
just need to fix my sink and determine if the radiator needs warranty coverage.
posting pictures in a second
bdog is offline   Reply With Quote
Old 02-25-2020, 04:38 PM   #2
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Tough to say without pics but check every hose, usually hand tightening is enough and they may have a gripping nut that lets you tighten by hand.
Check the drain where it meets the sink. Mine was missing some plumberís putty and leaking from there. Check the pipes from the drain - thereís 2 or 3 places to hand tighten the connections assuming theyíre sitting together flush.
Do include pics of where itís leaking from and maybe others will have better info.
Not sure about whatís exposed with your radiator but until you fix the leak, cover the exposed electrical part with a plastic trash bag or something. If the unit is fried Iíd call the factory and see if itís covered under warranty with a leak in the sink.
Frustrating - but it will work out. Good luck!
Old 02-26-2020, 02:32 PM   #3
Airstream Ambassador
AirstreamInc's Avatar
Jackson Center , Ohio
Originally Posted by bdog View Post
hey guys-
Hi bdog,*
We're sorry to learn about the issue you are having. Please send us a direct message with your contact information and the last 6 digits of your VIN so we can share it with our Customer Service and Technical Support team. We look forward to helping you get this resolved.
You can also reach Airstream Customer Service and Technical Support at*customersupport@airstream.com
Thank you.
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
AirstreamInc is offline   Reply With Quote
Goin' down, down, down... Aironius Axles 12 08-23-2014 08:09 AM
71 Kitchen Faucet Leaking Lumatic Sinks, Showers & Toilets 8 08-12-2009 08:44 AM
How to remove/repair leaking B/R faucet azfiredog300 Sinks, Showers & Toilets 6 10-25-2008 11:59 PM
Leaking kitchen faucet 99Limited34 Plumbing - Systems & Fixtures 4 10-17-2008 10:35 AM
kitchen faucet leaking Stefrobrts Fresh Water Systems 10 03-16-2004 09:44 AM
