Old 10-25-2019, 12:09 PM   #1
2012 16' Sport
Sedona , Arizona
Leak in shower drain assembly/p-trap - 2012 16' Bambi Sport
I noticed water leaking from the belly skin when using the shower in my 16' Bambi Sport. After cutting an access opening through the belly skin, I discovered the leak to be in the tailpiece/p-trap for the shower drain and replaced the p-trap and tailpiece but I can't seem to get the leak to stop. It is not clear if the leak is in the tailpiece connection to the shower drain, or the tailpiece connection to the p-trap. In either case, the fittings are extremely hard to access and getting proper tightening is a challenge. Hand tightening was not enough and I have been careful not to overtighten with pliers. The existing fittings had a blue, gummy material on the threads which I assume was applied at the factory to prevent the fittings from becoming loose and reducing the chance of leaks. Typical tools such as pump pliers are almost impossible to use in the limited space to access the fittings. This is driving me batty! Any ideas would be appreciated. Such a simple fix if it were under my kitchen sink.......
debrunyon is offline   Reply With Quote
Old 10-25-2019, 12:19 PM   #2
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
I’ve had a leave there before. Best advice I can give is to remove the entire P-trap and clean everything then reinstall with fresh plumbers putty and Teflon paste
Old 10-28-2019, 07:37 AM   #3
2012 16' Sport
Sedona , Arizona
Teflon paste must be the key
Thanks so much for your advice. I had not previously used teflon paste but I did as you suggested and no leaks! Thanks again!
Shower Drain Leak 2012 16' Sport debrunyon Sinks, Showers & Toilets 3 01-03-2021 12:28 PM
Drain Assembly Shower Pan Tony S General Repair Forum 16 08-05-2013 04:20 PM
Shower drain have a P-trap? guntertl Plumbing - Systems & Fixtures 2 01-08-2012 08:27 PM
Frozen shower drain trap 3 Dog Nite Winter Living 4 01-20-2009 01:51 PM
