06-19-2023, 07:37 PM
1999 25' Excella
Tucson
Information on replacement toilet
I need to know which toilet is a direct replacement for a galaxy starlite gl parchment w s tan pad 20907 in a 1999 excella center bath 25' Would Thetford be the best place to inquire?
Joe in Tucson
06-19-2023, 09:01 PM
1977 31' Excella 500
West Sacramento
I replaced the original galaxy starlight with a Thetford Bravura with the additional base to make the toilet higher. It has worked fine for 11 years. The Bravura has a wide base like the Galaxy, which I wanted so as not to put all the stress and pressure on the flange in the floor. It also has the foot pedal to fill/flush similar to the galaxy.
06-25-2023, 10:17 PM
1999 25' Excella
Tucson
Did the bolts on the flange line up?
06-26-2023, 03:14 AM
1995 25' Excella
xxxxx
, xxxxxx
I used a Thetford Aqua Magic Style II low model. It has a china bowl. It is much nicer than the original toilet. The flange bolts did not line up. Changing the flange was no big deal.
06-26-2023, 04:11 AM
1999 25' Excella
Tucson
How did you get the flange off?
06-26-2023, 08:23 AM
1995 25' Excella
xxxxx
, xxxxxx
Perhaps your trailer is different than mine....My toilet is a low model. It sits on a wooden box built up from the floor. That box has an access panel on the front. The flange is glued to an elbow with a short piece of pipe on it. The pipe goes in the black tank opening and is secured with a large hose clamp. With the clamp loosened the flange assembly pulls right out.
06-26-2023, 08:34 AM
1999 25' Excella
Tucson
I love this sight!!!!
Thank you,
My trailer is the same,so this helps me a lot. I have to remove the original carpeting to find the access panel. This sight is a great resource for almost anything you need.
06-26-2023, 09:10 AM
1995 25' Excella
xxxxx
, xxxxxx
On my trailer, the panel is held on by two press fit cabinet latches like the one that holds the Zip Dee chair cabinet door closed. It pried off fairly easily. I put a drawer knob on mine to make it easier to pull off in the future.
06-26-2023, 10:11 AM
1999 25' Excella
Tucson
I’m glad I didn’t start hammering on the flange,before you answered me!
07-02-2023, 05:26 PM
1999 25' Excella
Tucson
I purchased the Aqua Magic 2 also. Did you add a sprayer from the original toilet, and if you did is the tube on the water valve were you connect the hose from the sprayer?
Thanks again
07-02-2023, 05:29 PM
1999 25' Excella
Tucson
I purchased the same toilet. Did you use the original hand sprayer on the new one,and if you did were did you connect it?
