Thanks for the link.
It looks similar to the one I linked above from Home Depot. I got this today. It uses a rubber gasket to make the seal into the 3” pipe.
https://www.homedepot.com/p/OATEY-Tw...kA0IwzZ2VE4wo0
The foam ring on the toilet seems to just barely make contact on the flange.
Home Depot did not have a thicker ring in the same diameter.
I did get kit that has a slightly thicker ring, but the diameter is not the same.
**I have not tested any new seals on the toilet yet. I will test them tomorrow, looking for opinions on these seals I have.**
The kit also has a blue rubber seal with a foam ring. The rubber seal combined with a foam ring looks to be thicker to allow a tighter seal. I need to see if the blue cone slides into the flange.
Or can I stack 2 foam rings on top of each other?
I’ll try them tomorrow and see what seals best.
All I’m looking for here is a solid seal between the toilet and the flange, correct?
1st picture is the original ring on top and slightly thicker ring.
2nd picture shows diameter difference between the rings in 1st picture
3rd and 4th picture shows the original ring with the ring from the blue gasket. (I removed the foam ring from the blue piece, in case I can double stack)
5th picture shows the blue piece with its foam ring.
What looks best to use?
