Old 03-11-2023, 11:51 PM   #1
baggs's Avatar
2013 23' FB International
aldinga beach , south australia
HELP! shower drain
Hi!ive opened up the access hatch on my inter 23fb
to access shower P Trap...as i need to remove the shower floor drain as well and replace with new
what tool can reach up there and twist off the locking nut for shower drain?
a plumbers crows foot tube wrench?
DO I NEED TO REMOVE UNDER CHASSIS BELLY PLATES FOR BETTER ACCESS?
warm regards from the Land of Downunder
baggs is offline   Reply With Quote
Old 03-12-2023, 06:49 AM   #2
rbs
rbs's Avatar
2015 30' Classic
Decatur , Illinois
is it not draining or something else? If not draining, try pouring some vinegar down it and let it set, then use air pressure to blow it clean. I use a cheap plug for the drain, drilled a hole in it and installed a metal valve stem and used a compressor at 60 psi and it worked. I could post a picture of my "invention" if my explanation isn't clear
That trap looks very difficult to remove, if not impossible.
rbs is offline   Reply With Quote
Old 09-21-2023, 12:12 AM   #3
2016 23' International
TROY , NY
help
how did you open the access hatch for the shower drain...is it the panel below the shower door???....i took the 4 screws out but the panel is wedged in so tight that i cant remove it...any ideas???
deborah1029 is offline   Reply With Quote
Help! Poo smelling water coming up from shower drain! mdwesley Sinks, Showers & Toilets 10 07-13-2020 12:53 PM
Shower Drain on Bambi 16 Leaking, Help! Combsl Sinks, Showers & Toilets 0 07-19-2015 04:53 PM
Re working kitchen drain- pex for drain lines?? bwilson1 General Repair Forum 4 04-20-2014 08:42 PM
Help! Yucky clogged shower drain Blu_Hwy_Lady Waste Systems, Tanks & Totes 25 05-10-2006 01:07 PM
A/C Drain ...leaking at drain hose connection Sav'h Steve Furnaces, Heaters, Fireplaces & Air Conditioning 5 08-01-2004 04:09 PM
