Old 06-06-2020, 11:00 AM   #1
1987 31' Excella
Perryville , Kentucky
Help! Poo smelling water coming up from shower drain!
Working on ripping out cabinetry in bathroom. Husband had to use a saw saw to remove some pieces. A foul smelling liquid started coming up from shower drain. Anyone know the source? Any solutions?
mdwesley is offline   Reply With Quote
Old 06-06-2020, 11:03 AM   #2
aftermath's Avatar
Spokane , Washington
Any stagnant water will provide this experieince. It could have just been water left in the trap. Any water in the gray tank, even clean water left after a flushing will turn putrid over time. Rinsing and flushing before working on water pipes is usually the way to go.
aftermath is offline   Reply With Quote
Old 06-06-2020, 11:09 AM   #3
1987 31' Excella
that explains the foul odor, but why would water come up from the drain?
Old 06-06-2020, 04:28 PM   #4
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
No water in the P trap to block it.
With the lake handy at our favorite CG...we have to remember to pour a bit in once in a while.
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
"Sticks & stones will break their bones, ignoring will get it over with."
RLC
Tahawus....🌥
Old 06-06-2020, 07:35 PM   #5
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Water won't run uphill. And water isn't generated by removing bath cabinetry. I think the problem is something else going on.
Your tub has a P trap under the drain as Robert said, and then the water goes to a "grey" water tank. Water will accumulate in the tub if the grey tank is completely full. It is possible to transfer toilet water from the black tank to the grey tank if both dump valves are open, the the sewer hose connection cap is on tight. Maybe that happened in your project. Maybe your trailer is parked nose high allowing the water in your tanks to accumulate at the rear of the tanks.
Anyway, you can make dirty water go away in the tub by draining both of your waste water tanks. A good flushing of the tanks will also help eliminate orders. And then you can put some fresh water in the tub drain to fill the trap and seal off orders.
David
WBCCI #8607
VAC Region 11
Link to my 1975 Overlander Improvement Journal:
https://www.airforums.com/forums/f17...ml#post2053792
Link to our 1976 Renovation Project:
https://www.airforums.com/forums/f221...ct-202081.html
Old 06-07-2020, 12:19 AM   #6
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
After draining both tanks, and possibly spraying the black tank through the opened toilet flange, refill both tanks and add a reasonably potent dose of chlorine bleach. Let that sit for 2 hours at least, then drain both tanks. Rock the trailer for and aft with the tongue jack to get the last of the water. Especially worth the extra steps if you aren't planning to use the trailer for a while!
Old 06-07-2020, 10:32 AM   #7
Married with Airstream
drbrick's Avatar
2004 25' International CCD
Vancouver Island , British Columbia
The question I have is "do you have a 'grey water tank' or a single combo 'black/grey water tank'?? Also, remember that the 'shower/tub drain' is very low - only a couple of inches above the top of the tanks themselves. We have found that driving in hilly country can cause the tanks (if full) can backup into the shower so we put a stopper in the drain when travelling. Also, we add a bit of water to the drians to insure the traps have water in them to keep the tank odors from coming up...
La Dolce Vita Brick & Mona
We're Married With Airstream
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD FX4 SuperCrew Lariart (MaxTow) "Red Dragon"
drbrick is offline   Reply With Quote
Old 06-07-2020, 01:44 PM   #8
bibbs's Avatar
1977 Argosy Minuet 6.0 Metre
1973 21' Globetrotter
1975 26' Argosy 26
Vista , California
Backwashes can be prevented with the new check valve traps, I forgot what they are called, someone else will know and chip in. By removing the cabinets you may have changed the pitch of the drain pipe which may of had water in it
bibbs is offline   Reply With Quote
Old 06-07-2020, 06:15 PM   #9
1987 31' Excella
Thanks for all of your allís great advice! The trailer was sitting slightly nose high (with bathroom in back) we leveled it out and havenít had any more issues. Unfortunately, we arenít in a place to empty our tanks which may be full from previous owner 🤢. That is definitely on our to do list.
Old 06-07-2020, 06:29 PM   #10
2018 25' International
Slidell , Louisiana
Get yourself some happy camper and add it to the shower. flush it into the grey tank with a gallon of water or less. Let it sit for a couple days and then next time it is about to rain hard just slowly dump the grey water onto the ground as the rain starts. You are not putting anything into the ground that is not already there. As others indicate even grey water will grow anaerobic bacteria which will convert sulfates to H2S and now you have the poo smell. happy camper reacts with H2S to eliminate it and it is natural.
Brian
BayouBiker is online now   Reply With Quote
Old Today, 12:53 PM   #11
Retired
tvketchum's Avatar
2008 30' Classic
Livingston , Texas
If you are at home, and, you have sewer clean-outs in the area, you can drain into those.
Tom
AIR 71620
WBCCI 5809 Reg 9 Unit 155
2008 Classic 30'
2019 F250 4x4
tvketchum is offline   Reply With Quote
« Faucet leak | Top | - »
Cleaning Off Aphid Poo RedDogBullet Cleaning, Stripping & Polishing 9 09-30-2012 04:42 AM
Smelling the heat! Luftnoggin Furnaces, Heaters, Fireplaces & Air Conditioning 8 09-18-2011 10:55 PM
How to keep the Refrigerator sweet smelling when not in use Airperson Refrigerators 7 09-11-2011 06:36 PM
water coming out pressure regualtor drain line when on city water txstreamer Fresh Water Systems 7 09-16-2010 03:07 PM
