Old 02-26-2024, 12:27 PM   #1
2019 27' Tommy Bahama
Question Flush Water Leaks/Drips into Toilet Bowl
I've searched these threads and can't find a similar issue.
We have a 2019 FB27 and this last trip we noticed that when hooked up to outside water, you'd flush the toilet without a problem....but the water would continue to "leak" into the bowl, much like a faucet leak/drip. It wasn't so severe as to fill the bowl in a short time, but the only way to stop it was turn off the ball valve on the supply on the floor next to it.
What do I need to do to resolve this issue? (I'd know what to do on a domestic toilet, but no idea on this one!)
Mark of SJC is offline   Reply With Quote
Old 02-26-2024, 02:33 PM   #2
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Santa Fe , New Mexico
On the back of the toilet there is a valve at the water line inlet. Need to replace that valve otherwise your toilet will continue to fill. Easy job, just google it.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 02-28-2024, 03:03 PM   #3
Thanks very much for the response!
I'm having a devil of a time figuring out who the toilet manufacturer is to figure out the part I need to order. All I can find is "ceramic toilet"
Any ideas?
Old 02-28-2024, 05:28 PM   #4
Lost in America
mojo's Avatar
Should be Dometic. The valve is held in by two screws and two release clips. Once you get it out, you can compare to images online.
2017
Miscellaneous A/C drips/leaks dznf0g General Repair Forum 10 08-20-2014 07:03 PM
Toilet-Aqua Majic 30 leaks water into bowl 2coldnpagosa Sinks, Showers & Toilets 4 09-10-2010 08:47 PM
Leaks, Leaks and more leaks Jim in Pima Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 12-12-2007 11:23 AM
Leaks, leaks, leaks jeffnjen30 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 08-27-2007 11:03 PM
leaks leaks leaks Globie64 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 12-31-2005 05:49 PM
