Old 03-18-2020, 03:35 PM   #21
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Originally Posted by OTRA15 View Post
Re: "known problem?"
That earlier thread was started on 4/30/19, almost a year ago.
Yes, putting electronics under the sink gives one a sinking feeling!
Don't you sink?
Ummm...I'll see your sink and clog your drain.🥴
Originally Posted by jfreeham View Post
Not to diminish turk123's experience, and it is unfortunate it happened, but I wonder how often the sink falls under a counter in an AS?
Well...It's not unsinkable.😂
Obrigado, ť hora de descansar.
Tahawus
Old 03-18-2020, 03:43 PM   #22
Sag Harbor , New York
Originally Posted by ROBERT CROSS View Post
Well...It's not unsinkable.��
I sunk so!
Thanks for the additional linked thread:
https://www.airforums.com/forums/f44...er-197068.html
Peter
Let the music lift you up . . .
[Robert Frost reading live -- 2 minutes]
Old 03-18-2020, 04:26 PM   #23
2010 30' Flying Cloud
fredericksburg , Texas
Start a petition here and maybe airstream will do a recall on this problem. Water and electric could cause a death.
fbgairstream is offline   Reply With Quote
Old 03-18-2020, 09:32 PM   #24
jamieb1086's Avatar
2016 25' Flying Cloud
Selbyville , Delaware
Well now, if I were to order a Classic, (which I wouldnít because there is too much complexity), I would order it with a manual awning. For crying out loud, give the customer the option. So if you LOVE the Classic, sorry Mr. Customer, you HAVE to have the electric awning with the poorly placed brains for it under the sink (even though you donít want it).
Plus youíll get all those electronic control panels that havenít thoroughly been de-bugged.
If someone from the Customer Advisory board is listening, canít AS offer upscale models with a few options that reduce the complexity yet still leave the luxury in?
The fewer hassles you have while youíre camping, the better.
Jamie
2016 25' RBT Flying Cloud "Bullseye"
2016 Chevy 2500 High Country Duramax Diesel "Red Bull"
WBCCI #9026 Watchung NJ Unit
jamieb1086 is offline   Reply With Quote
Old 03-18-2020, 09:50 PM   #25
1969 18' Caravel
Greenville , whereEverIroam
Images: 20
I guess the genius engineers considered mounting the awning electronics with the circuit breaker box, but there wasn't enough room for both under the sink.
skyguyscott is offline   Reply With Quote
Old 03-18-2020, 10:10 PM   #26
airstreambob's Avatar
1993 30' Excella
1992 21' Sovereign
2000 30' Excella
2001 31' Land Yacht
Valley Park , Missouri
Under mount Sink failures
The under mount sink falling out is an epidemic across all RV brands right now. My son has a Forest River Mini Lite that had this issue. A cruise through the Mini Lite forums shows a LOT of the same problem.
After the second failure, by now out of warranty. I helped him solve the problem.
See, his sink was attached with double sided foam adhesive tape! The factory repair? More of the same. Time for a home baked fix.
First, clean off any residual glue (or tape). Acquire a piece of furring strip long enough to cross your sink, then visit the local Harbor Freight for a pack of 11 or 12" Zip ties. You'll also need to pick up a tube of Clear Non Expanding Gorilla Glue.
Lay wood across sink. Bend 2 cable ties a couple of inches from the end so that you can feed them through the the grid in each drain hole. Pull then through and zip an inch or 2 forming a loop. Thread a second Zip tie through each of the first ones, making a second loop (like making links in a chain). In our case a third link was necessary. Feed the furring strip through the top links in your zip tie chain. Leave the links loose enough so that the sink "floats" under the countertop. Use a LOT of that glue, all the way around. When done, Pull on the top chain Link zip tie to bring sink up to snug with the underside of the counter. BE CAREFUL, IF YOU PULL TOO HARD, YOU COULD BREAK THE DRAIN! Let it dry overnight. Using sharp scissors, cut the Zip ties and remove. Sink will be substantially better than new. And, as a good caravaner, Save the Wood, the unused zip ties and glue and put them in your "emergency" tool kit! (I did this on a double bowl sink. If you have a single bowl round one, you would only use one zip tie chain)
And with a total cost of less than $10 for supplies, and a half hour of work, might save a long trip to the dealer.
airstreambob is offline   Reply With Quote
Old 03-18-2020, 11:01 PM   #27
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, and the basic Safari shines again. Not as pretty, not as fancy, but none of the problems.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
Old 03-19-2020, 02:37 AM   #28
Thumbs up
"Keep It Simple, Stu."
Old 03-19-2020, 07:37 AM   #29
1976 31' Excella 500
Chappell Hill , Texas
Plumber here. I hate under-counter glue on sinks. Even the kind with clips to hold it up. Self-rimming is the only kind I will own.
tbashin is offline   Reply With Quote
Old 03-19-2020, 07:46 AM   #30
2020 19' Bambi
Wilderness , MO
Robert, simplicity is the reason we bought a Bambi. Also, no RV is without flaws, but AS outshines then all. (I'm new here, but I bet that's the first time that pun has ever been posted.)
jfreeham is offline   Reply With Quote
Old 03-19-2020, 07:57 AM   #31
Thumbs up
Good one!
Welcome to the forum.
Peter
Old 03-19-2020, 08:34 AM   #32
2020 Globetrotter 25 FBT
GettinAway's Avatar
2020 25' Globetrotter
Wildwood , Missouri
I think the demand for globetrotters has been fairly significant. Along with other models that utilize corian countertops. So this problem will just get worse. The good news is, there is a fix, just like other issues with every style and model AS. We still really like the GT interior etc..
However, my sink is still in place, and my powered awning is working fine. I may be dancing to a different tune next year. Ha!
2020 25GT FBT
2012 Toyota Tundra Dbl Cab, 5.7 4x4
GettinAway is offline   Reply With Quote
Old 03-19-2020, 08:48 AM   #33
Mollysdad's Avatar
Originally Posted by lsbrodsky View Post
Why would undermount sinks make any sense in a vehicle pounding down the road for its lifetime?
Because it looks so good at the RV shows!
Sales. A thousand people saw it at the RV show, one person saw it fall out while boon docking.
Old 03-19-2020, 09:33 AM   #34
SHE SHED
trikdacy's Avatar
2019 30' Classic
Brooklyn , New York
Quite shocking since I have a pacemaker.
trikdacy is offline   Reply With Quote
Old 03-22-2020, 07:07 PM   #35
turk123's Avatar
2019 30' Classic
Canfield , Ohio
Now my 5 GFCI pugs are off and the inverter will not come on.
Water was still getting to the back of the cabinet and the awning controller is no longer flashing. It's all dead. Where the water came from, I do not know. It may be the drain connection loosened up from our traveling today. I did not replace the putty used on the drain.
The GFCI breaker will not come on and I fear something like the inverter has a short. It looks like the inverter has a small reset switch on the top corner and reads 12 amp, but it will not trip or reset. Is the inverter on the GFCI circuit?
I have a small LED light I plugged into the receptacle near the stove and I am getting a faint glow! Obviously the power to these 5 plugs is there but really reduced.
Anyone know what is going on????
x\x/x\x/x\x/x\x/x\101970\x/x\x/x\x/x\x/x\x/x\/x\x/x\x/x
Tom & Doty
2019 Airstream Classic 30 Twin
Link to our shared album: https://photos.app.goo.gl/wACfGg1KcroVLP5m6
turk123 is offline   Reply With Quote
Old 03-22-2020, 08:25 PM   #36
Hmmm . . . maybe those 5 "pugs" slipped their leads?
It may be time for a voltage meter to test -- with care -- the 120-volt GFI outlets, and other points IMO. Just make sure that a 120-volt wire is not shorting out on the trailer's framing/skin metal someplace. It might be dangerous to touch the exterior while standing on the ground barefoot, for instance.
You could unplug from shore power, and use the correct meter to check for short circuits, but this is above my pay grade.
Good luck,
Peter
Old 03-22-2020, 10:34 PM   #37
1969 18' Caravel
Images: 20
You might call JC Monday morning early and see if you can drop it off before Ohio shutdown on Tuesday. If it's a 2019, it should still be under warranty and they can sort out the consequences of their stupidity.
Perhaps "a light" will go on and they will find some other location for the electronics. In any event, perhaps it will do some good for them to see "what could go wrong?" by placing the electronics under the sink.
There is likely some moisture triggering the GFI; that is what it's there for. Then again, when it comes to electricity in an aluminum shell where they throw these things together, I would not assume there is not a short somewhere. I have seen threads here where owners discovered AS used cheap RV outlets they literally jam into the wiring, with blade contacts on the backs cutting into the wiring to make the connection, I kid you not.
Dropping it off at JC is a huge crap shoot, Ohio is shutting down on Tuesday, so all work at HQ will likely cease until further notice; it could literally be months.
Old 03-23-2020, 12:16 AM   #38
turk123's Avatar
2019 30' Classic
Canfield , Ohio
Right now I am literally watching my microwave come on and off and the charger fan turning on and off! My sofa usb lights are flashing and the night light plugged in at the stove plug is turning on and off. Everything just went dark!
Should I be concerned?? Micro wave just beeped and it came back alive? Fan on charger is clicking!
Guess All power gone
This thing has a mind of its own! Should I be concerned? Power just came back and now gone..
Tom & Doty
Old 03-23-2020, 12:19 AM   #39
turk123's Avatar
2019 30' Classic
Canfield , Ohio
Iím going to shut off breaker. This thing is alive! Microwave just came on and shut off. Beep! ****!
Tom & Doty
Old 03-23-2020, 12:25 AM   #40
turk123's Avatar
2019 30' Classic
Canfield , Ohio
Shut off GFCI breaker but microwave is still coming on and off! Itís on another circuit. This is spooky!
Microwave now on and rear tv just went out! Plugs in rear just went out.
What should I do?
Tom & Doty
South Dear Airstream - inverter outlets PharmGeek Boondocking 23 05-24-2017 05:04 AM
Saying goodbye to a dear, dear friend..... Silvertwinkie The Pet Forum 36 02-04-2008 02:42 PM
Replacing parts and making improvements don't stop in RV life Randall Airstream "In the News" 2 08-09-2006 10:08 AM
Argosy vs. Airstream-sinks and appliances Rick Alston All Argosy Trailers 14 01-22-2004 02:50 PM
