Yikes! It sounds as if you weren't doing something excessive to provoke the ding, so it seems to me that more cracks are in your future. Your .sig says you've got a 2015, so the brittleness probably isn't due to age. Epoxy and fiberglass mat would be a good fix, but you'd have to do probably the entire pan, to be sure that the floor is strengthened, and to not have an unsightly lump. While you're at it, maybe drill some holes through the pan and fill the gap under with foam to help support?
If the problem isn't fixed, you're looking at the dreaded floor rot down the line!
