03-13-2021, 11:12 AM
2021 20' Basecamp
Austin
Basecamp 20X exterior water leak
I recently purchase a new Basecamp 20X. I just noticed that after running the shower inside- there’s a leak underneath the trailer on sewage side. A pretty constant drip in two spots. Could this be from frozen/cracked pipes? Or is this an issue with new Basecamp that could be a leak.
03-13-2021, 11:19 AM
2007 30' Classic S/O
Somewhere
, South Carolina
I don’t own a base camp.
If the tank was leaking I’d suspect dripping off of the galvanized tank pan (lowest thing in your pic square corners etc) not the bottom of the trailer.
Any accessibility to see behind the shower or such that gives you visibility ?
And only happens after using the shower that does narrow the search a bit.
And yes w/o full winterization to get rid of all water that can be a cracked shower something. Cost me a shower head once that I didn’t get fully drained.
Gary
03-15-2021, 10:52 AM
Airstream Ambassador
Jackson Center
, Ohio
Attachment 390614
Hi ATXMarine,*
We're sorry to learn about the issue you are having. Please send us a direct message with your contact information, email and the last 6 digits of your VIN so we can share it with our Customer Service and Technical Support team. We look forward to helping you get this resolved.
You can also reach Airstream Customer Service and Technical Support at*customersupport@airstream.com
Thank you.*
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
03-20-2021, 09:26 AM
2021 20' Basecamp
Austin
@Airstream, I tried sending a DM but your inbox is full and unable to receive messages. I sent an email to the address provided and have not heard back.
03-22-2021, 12:32 PM
Jackson Center
, Ohio
Sorry about that, we have emptied our mailbox. Please try again if you still have not heard back from anyone.
06-07-2022, 10:08 PM
2022 20' Basecamp
Evergreen
Same problem
@ ATXMarine - Can you share how this problem was sorted out? I just de-winterized my brand new 2022 BC20X and have the exact same drips outside. Due to the slight tilt in my parking spot, I also have water pooling inside and seeping out from under the bathroom enclosure. I believe my issue is coming from the shower faucets as tinkering with the toilet and pouring water down the shower drain didn't produce a drop of water. Turning on the hot or cold shower faucets brought it almost immediately. So much for my inaugural trip this upcoming weekend...
06-08-2022, 08:02 PM
2022 20' Basecamp
Evergreen
Found the culprit
Water spraying as it leaves the faucet on its way to the shower head.
03-25-2023, 08:33 PM
Round Rock
What was the solution to fix the leaking? Thanks.
03-25-2023, 10:49 PM
2022 20' Basecamp
Evergreen
I replaced the faucet.
03-27-2023, 05:05 AM
Round Rock
Thanks!
05-25-2023, 05:46 AM
Littleton
Access to shower plumbing in basecamp 20X
I have a leak in my new 20X. It’s leaking outside below the shower. How do I access the shower faucet plumbing?
05-26-2023, 12:34 AM
2022 20' Basecamp
Evergreen
Remove the back panel on that shallow lower storage cubby between the bathroom and the back bench seats. I believe there's a post somewhere on that particular process. I think the lower/bottom panel comes up first after removing a few screws and then you can take out the back panel in similar fashion. If you're a larger person, find a smaller one to help you. I'm 5-10 and about 170 lbs, and I had to be a contortionist to get back in there. I was legitimately concerned about getting stuck. Best of luck to ya!
