Old 05-17-2021, 10:57 AM   #1
aaryno's Avatar
1972 31' Sovereign
Tucson , AZ
Attaching to Natures Head urine drain
For those who have used a Nature's Head composting toilet and diverted urine to the black tank, what did you use to connect your drainage system to the urine drain?
I have a 1.5" hepvo (could go with a 1.25" too) and a 1.5" ABS system I am connecting with.
aaryno is offline   Reply With Quote
Old 05-17-2021, 08:46 PM   #2
aaryno's Avatar
1972 31' Sovereign
Tucson , AZ
was thinking something like this
https://www.zoro.com/banjo-1-female-...BoCQz0QAvD_BwE
Old 05-17-2021, 09:18 PM   #3
Long Island , New York
FYI/FWIW -- You have probably seen all these "composting toilet urine drain" threads:
https://www.google.com/search?q=comp...=airforums.com
. . . so maybe helpful for other readers IMO.
Good luck.
FYI
FWIW
Let the music lift you up . . .
Old 05-17-2021, 11:15 PM   #4
aaryno's Avatar
1972 31' Sovereign
Tucson , AZ
Good luck.
FYI
FWIW
yes, Otra15, iíve been doing my homework. iíve seen a lot of these threads. itís a very common mod but the threads iíve read lack detail on the parts needed to actually connect the NH urine drain to a drainage system or donít accomplish my primary design criteria:
1) aesthetically clean (donít want hose clamps and 4 different types of fittings under the toilet)
2) doesnít smell (needs a valve).
the approaches iíve read so far utilize the following approaches:
1) hose clamp with flex tube to grey/black tank
2) rubber compression fitting to standard 1.5Ē ABS
3) drain hole and tube in the pee tank itself.
since iím running this to a tank 7 feet away i was planning on using 1.5Ē ABS, which is admittedly pretty large but i can put a hepvo valve on it and keep vapors from the tank from coming back into the trailer.
solution 2 is closest to what i want but in terms of aesthetics and convenience iím looking for something better. iíd rather have a quick release than have to loosen a hose clamp to pull the top off to swap out the bag of solids. iíd also rather have a simpler attachment below the tank and not have 4 different fittings just to connect to the ABS. so those are my motivations.
i just spent an hour at the hardware store trying to piece all the right fittings to make a clean solution and ultimately didnít figure it out so thatís why iím reaching out to the forums. i assume you are trying to be helpful with your ďlet me google that for youĒ... if you have actual experience with this i would be grateful for your insight.
Old 05-18-2021, 09:47 AM   #5
1959 24' Tradewind
Twin Falls , Idaho
arryno - these guys installed one on the schoolie in this video. I thought of doing the same thing, but haven't yet.
Regards,
Tony
Trons4u is offline   Reply With Quote
Old 05-18-2021, 08:11 PM   #6
aaryno's Avatar
1972 31' Sovereign
Tucson , AZ
thanks! it looks like they just put the hepvo directly under the urine drain: Click image for larger version
Old 05-18-2021, 11:02 PM   #7
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
I plumbed my AirHead directly to the black tank with check valves. No smell what so ever. However, occasionally I run some water through the system with the old toilet cleaning hose.
guskmg
Natures head with urine diversion install: 310 motorhome Magnet18 Sinks, Showers & Toilets 9 08-04-2020 10:03 PM
Composting toilets: Natures Head or Airhead? andreasduess LP Gas, Piping, Tanks & Regulators 18 11-19-2015 07:59 PM
Natures Head power requirement steveirving Waste Systems, Tanks & Totes 12 11-14-2015 03:37 PM
Natures Head Power and Venting steveirving General Repair Forum 4 02-18-2013 12:14 PM
