Old 11-08-2024, 02:59 PM   #1
2022 25' International
Catonsville , Maryland
2022 25' FB Toilet
I'm seeing the toilet leaking from under the base. I checked the supply lines and foot pedal and don't see any obvious leaks there.
I see from the parts manual that this is listed as "690621-BOX Toilet, China, Dometic".
Can anyone confirm that this is the 300 series Dometic toilet? I'm assuming thats an easy disconnect and swap.
Ben Brouse
Ben B is offline   Reply With Quote
Old 11-08-2024, 05:40 PM   #2
daleyocum's Avatar
2018 25' Flying Cloud
Portland , Oregon
Ben Brouse
A call to Airstream might be in order if no one has the answer. Woodland Airstream has the exact one https://woodlandairstreamparts.com/p...ite-690621-box
daleyocum is offline   Reply With Quote
Old 11-09-2024, 01:04 PM   #3
Old 11-09-2024, 03:05 PM   #4
Steamy1's Avatar
2015 23' FB International
2007 19' International CCD
Steamboat Springs , Colorado
If it is a 300 series you may want to check out Panther RV. I have found their pricing constantly competitive.
I have ordered several items from them including a Maxx Fan.
Just a suggestion.
I have also purchased many times from Woodland. Great source for Airstream specific parts.
"Keep your eyes on the road
Your hand upon the wheel"
Steamy1 is offline   Reply With Quote
Old 11-17-2024, 11:09 AM   #5
2019 25' Flying Cloud
Sequim , Washington
Ben Brouse
I had a similar leak on my previous AS (23’ FC). All it needed was a new gasket. An easy repair. Maybe you don’t need a new toilet?
D2
"Having differences makes a difference"
WestieHouse is offline   Reply With Quote
Old 11-17-2024, 12:04 PM   #6
2014 25' Flying Cloud
Temple , Texas
Best place to get new one is Amazon. If it leaking from the seam you need a new one. From the base it may be the seal if you are lucky
2014 Flying Cloud 25FB
2018 Ram 2500; Cummins
Blue Ox WDH
RamRider is offline   Reply With Quote
Old 11-18-2024, 11:40 AM   #7
kbmwrs's Avatar
2016 25' International
Morgan Hill , California
Mine a 2016 FB 25 also leaked from under base. Removed toilet and found two long sheet metal screws were laying across the gasket tilting the toilet thus not s full seal.
Before buying new. Check the seal.
kbmwrs is offline   Reply With Quote
2022 GT 27 FB Twin inverter upgrade. Do 2022 trailers have a fridge roof vent? foobar Batteries, Univolts, Converters & Inverters 19 07-23-2024 10:12 AM
2022 Bambi 20FB Toilet Change Out LowOnCash Sinks, Showers & Toilets 6 11-14-2022 08:28 AM
2022 Caravel 22FB Toilet ? kingsolomon Plumbing - Systems & Fixtures 0 08-05-2022 08:54 PM
Changing a toilet to a standard toilet bamamama Waste Systems, Tanks & Totes 8 07-21-2012 07:12 PM
Replacing old platform toilet with "regular" toilet? Mrs.S Plumbing - Systems & Fixtures 4 11-21-2011 04:52 PM
