05-28-2022, 02:19 PM
2008 28' International
Appleton
, Wisconsin
Why does my hot water heater propane make this noise?
So, the propane on my hot water heater is sounding strange lately. Any idea what is causing it, and how to fix it?
It kinda sputters, I’m wondering if there’s some buildup that needs to be cleaned, but I’m not sure how to even get in there if My theory is correct.
Here’s a video of it (easier than trying to describe)
https://youtube.com/shorts/x5S_RhmfeBY?feature=share
2008 28’ International
05-28-2022, 05:11 PM
Jim J
2014 30' Flying Cloud
Austin
Check inside the flue for small bugs or bug nests. I had some in mine a couple of years ago, They prevented the air and propane from properly mixing causing that sputtering sound and sending out a lot of black smoke.
05-28-2022, 05:25 PM
2005 30' Classic
Kingston
It could be the air/fuel mixture. There is a sliding collar with oblong holes on the tube that the propane jets into. Loosen the screw and slide the collar back and forth while the burner is running until it sounds smooth, then tighten the screw.
05-29-2022, 06:09 AM
2017 30' International
Broomfield
Yes I believe this is an fuel/airflow issue. Remove and clean the small air/fuel mixing tube with a small wire brush and you should be good.
05-29-2022, 06:16 AM
2007 30' Classic S/O
Somewhere
, South Carolina
Just to the left of the air shutter is the propane orifice. My .02$ remove air shutter, then remove the orifice and look for a small piece of debris that is flopping around and randomly interfering with propane flow.
I’ve found dried pipe dope and bug larvae in propane orifice.
Gary
Atwood water heater, gas burner sputtering.
https://www.airforums.com/forums/sho...d.php?t=219946
05-29-2022, 09:24 AM
1996 25' Excella
Tillsonburg
, Ontario
Sputtering or gurgling is usually too much air.
As noted above move the collar to reduce the opening. You should see just the tiniest tip of yellow in the flame and the noise should be smooth and steady
05-29-2022, 09:29 AM
Spokane
Did anyone else have trouble getting the OP's link to work?
05-29-2022, 11:03 AM
2009 25' FB International
2018 27' Globetrotter
Hanover
, Pennsylvania
Yes. But I just copied it and pasted into Safari and it went right to the YouTube video.
05-29-2022, 12:50 PM
2006 34' Classic S/O
1994 28' Excella
1950 19' Globetrotter
Elgin
This from the Atwood service brochure...
- Low gas pressure
- Poor gas supply
- Improper air adjustment (as mentioned above)
- Poor main burner alignment
- Misaligned burner flame spreader
- Blocked burner orifice (clean it and DO NOT enlarge it)
- Obstructed main burner
- Obstructed "U" tube (as mentioned before)
- Obstructed exhaust grille
All The Best...
'Ol Bob
06-09-2022, 08:06 AM
Appleton
, Wisconsin
Thx!
Thanks everyone, this solved the problem: take the unit apart and clean out any debris (there was a fine dust in the large pipe).
Reassemble and everything was quiet once again.
