Old 09-16-2024, 11:16 AM   #1
2018 25' Flying Cloud
Albuquerque , New Mexico
Question Which way to turn the now closed heater bypass valve
My 2018 25ft Flying Cloud FBT has a small opening for the bypass valve location. It is now in the closed position. I would love to know which way (clockwise or counterclockwise) to turn the incredibly hard to turn valve, so as not to break it. It appears to be fragile plastic.
rad-rt66 is offline   Reply With Quote
Old 09-16-2024, 11:58 AM   #2
daleyocum's Avatar
Portland , Oregon
This video is generic, not Airstream specific, but explains bypass valves pretty well. I never use mine since I don’t add antifreeze to winterize, I just use compressed air.
daleyocum is offline   Reply With Quote
Old 09-16-2024, 02:52 PM   #3
Thanks.
Yep, the video does not come close to showing what I need to know. I do appreciate your tip about never using that valve but blowing out. We received this trailer and this is the first time and I am trying to get it ready.
Old 09-16-2024, 03:43 PM   #4
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
I just checked our 2019’s water heater bypass valve and found there’s a positive stop when closed. You should be able to determine the correct direction to rotate it by checking this first.
Move it in the opposite direction so the valve handle is parallel to the pipe (open position).
Hope that helps!
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
jeffmc306 is offline   Reply With Quote
Old 09-16-2024, 04:03 PM   #5
waninae39's Avatar
2022 25' Flying Cloud
NCR , Ontario
most modern valve handles work the same
ie if the handle is inline with the pipe it is open
if its perpendicular, then its closed
in the picture above, the valve is closed
2023 25' FB FC, hatch, Queen,30A,1AC,Awning pkg, Convection uwave.Multiplus 12/3000-50,700A Lion,MPPT 100/30,Orion-TR 30,Cerbo GX,GX touch 50,Lynx distributor,dual BMV-712, smart shunt 500A&1000A, RUUVI temp/humidity sensors,2 Mopeka LP sensors
NCR,Ontario,VE3HIU since 1978
WBCCI# 21212
waninae39 is offline   Reply With Quote
Old 09-17-2024, 10:12 AM   #6
BigHornStream's Avatar
2017 25' Flying Cloud
Sheridan , Wyoming
Access to the bypass valve is the key. I remove the plywood panel underneath the mattress to get full access since the hole in the panel is too small for my hand. Even then the access is still quite restricted but at least I can turn the valve, and, mine is also incredibly hard to turn. Hope this helps.
BigHornStream is offline   Reply With Quote
Old 09-17-2024, 11:22 AM   #7
2014 25' FB Flying Cloud
Albany , Oregon
I cut a 6" piece of 1/2" OD brass tubing (you can use any pipe) to use as leverage to open and close that valve. Slip it over one end and you can easily turn that valve.
FlyingCloud7 is offline   Reply With Quote
Old 09-17-2024, 01:16 PM   #8
2020 27' Globetrotter
FALL CITY , Washington
Ccw
If you can’t see the valve stop which provides a clue to direction to open, mine is counter clockwise to open.
Jeff
2019 27 GT
Applej is offline   Reply With Quote
Old 09-17-2024, 02:32 PM   #9
2023 27' Flying Cloud
Buford , GA
Winterize valve in 2023 FCFBQ
Here is the tag from our 2023 FCFBQ. The valve only rotates 90 degrees between these two positions.
J & B with Izzy the standard poodle
2023 FC27FBQ with a hatch! BRN 20813
2023 F-150XLT 4x4 5.0 max tow
JBamadon is offline   Reply With Quote
Old 09-18-2024, 10:05 AM   #10
Thumbs up I've figured it out. Thanks to all, stop replying
I figure out how to turn my valve. No stop tabs, no indications, but now in line with water flow.
Old 09-18-2024, 10:11 AM   #11
Smile Got it figured out !!!
Finally figured out the direction. No valve stop, no indicators, just went for it with water flow direction downstream.
Thaks All...
Water heater bypass valve lucybear Water Heaters, Filters & Pumps 22 02-13-2023 08:48 PM
Location: Water heater bypass valve? Will_Brule Water Heaters, Filters & Pumps 17 10-08-2019 05:06 AM
Water heater bypass valve on Interstate Ext Lounger drguthman Our Community 0 01-23-2017 07:51 PM
Water heater bypass valve Robfike General Motorhome Topics 6 05-11-2014 07:21 PM
Bedroom Lights Don't Turn On/Turn Off and turn back on after a couple minutes. alecg Lights - Interior & Exterior 9 09-01-2010 03:01 PM
