Old 04-19-2024, 10:27 AM   #1
2000 25' Safari
Denver , North Carolina
Where’s the mixing valve?
2000 Safari twin. After looking around the forums. I think I need to clean or replace my mixing valve. I have all the original schematics. I have good access to the WH from inside under the bed. Can anyone help me find where the mixing valve is? Schematic attached
ID:	442874   Click image for larger version
mbubbaca is offline   Reply With Quote
Old 04-19-2024, 12:05 PM   #2
Malia20's Avatar
2017 20' Flying Cloud
Oriental , North Carolina
hot water mixing valve
You do not have a mixing valve. If you did it would be where the hot water leaves the tank and where bypass cold water comes in from the cold line. In this style of plumbing there is just one valve to shut or opened to bypass the hot water tank or to use the tank. Your picture and schematic show three valves to bypass and no mixing valve. To bypass you have to shut the red line (hot) and white line (cold) valve and open the valve where the line switches from white to red (the bypass valve). This forces cold water to not enter the tank and go to the hot side, but as cold water. In hot water mode, the three valves are the opposite. If any one of these valves is wrong....you will not get hot water or it will be warm at best. Check the valves.
Safe travels.
Fred
Malia20 is offline   Reply With Quote
Interstate Shower Head / Faucet / Mixing Valve nvestysly Sprinter and B-van Forum 15 10-23-2017 05:37 PM
2017 Classic Hot Water Mixing Valve Calibration rivetville 2016 - Current Classic (all lengths) 74 08-17-2017 04:20 AM
Shower Mixing Valve Cartridge Replacement jmellana Plumbing - Systems & Fixtures 2 07-29-2017 11:34 AM
Atwood XT Water heater mixing valve orloffgray Plumbing - Systems & Fixtures 0 03-23-2016 07:55 AM
Need mixing valve G. Traveler Sinks, Showers & Toilets 5 11-01-2011 06:15 PM
