Old 05-30-2023, 07:59 AM   #1
2020 25' Globetrotter
Westboro , Massachusetts
Water temp uncontrolled
Hi! We have a 2020 globetrotter that’s new to us. Used it this weekend for the second time. The water heater works BUT the hot water gets soooo hot AND it comes out scalding even when the faucet is set to cold. It was even hot when we turned off the hot water connection under the sink. Suggestions before we take it in for service?
Curran is offline   Reply With Quote
Old 05-30-2023, 09:45 AM   #2
damonbeals's Avatar
1998 31' Excella 1000
1979 23' Safari
Mooresville , Indiana
Well, you can't get hot water into the cold side so maybe faucet is faulty? The water heater does have a mixing valve, and it's job is to prevent scalding, so I would bet the valve is full of crud and not working right. Search airforms for 'mixing valve'
Damon
#4827
damonbeals is offline   Reply With Quote
Old 05-30-2023, 01:36 PM   #3
It’s happening at both faucets and the shower head. I’ll check the mixing valve as you mention. Thanks! Any tips for searching successfully? I search and get a bunch of seemingly unrelated things.
Old 05-30-2023, 01:46 PM   #4
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Curran,
Sorry don't know what's going one but maybe a diagram of the plumbing system can help you see the system and de-bug it. I took a quick look at a Globetrotter parts manual and page IV-12 shows a 25' FB.
Gary
https://www.airstream.com/owners/man...r/2020/page/2/
GCinSC2 is offline   Reply With Quote
Old 07-30-2023, 08:55 AM   #5
Finally getting around to trying to fix this - in the summer months have just been getting by with the water heater off. I want to try and clean out the mixing valve as mentioned, but I can’t find any instructions. I know nothing about plumbing (maybe I shouldn’t attempt this). I know where the valve is. But, how do I ensure there’s no water in the valve before I remove it? Anyone have/can link me to any more detailed directions on this?
Old 07-30-2023, 06:34 PM   #6
2021 22' Caravel
Houston , Texas
Most household systems have a replaceable cartridge in the mixing valve and I suspect the same for the airstream. If you get these conditions in a household system then it is usually the cartridge that gets clogged up with either debris from unfiltered water or from calcium from hard water (common in the west).
I would start by finding out if there is a replaceable cartridge in the mixer valve. Long term I would ensure your water entering the trailer is conditioned through filtering and softening.
FredWilma is offline   Reply With Quote
Inside skin temp to outside skin temp DrivingDan General Motorhome Topics 19 10-16-2022 08:13 PM
Freezing temp ext. Water line LisaP Winter Living 11 01-10-2011 02:45 AM
Adjusting Water Heater Temp? Gastrolith 2005 and newer - Bambi all models 4 05-05-2010 11:29 PM
Water heater - can't find temp control dano Water Heaters, Filters & Pumps 6 05-04-2010 06:36 AM
Low water temp..2003 Airstream Classic ROBERT CROSS Water Heaters, Filters & Pumps 8 07-29-2007 09:24 PM
