Old 05-19-2025, 11:49 AM   #1
2011 27 FB International
Covington , Washington
Water Pumping Issue
We have a 2011 International, and are currently troubleshooting a water problem back home not traveling. I welcome any suggestions. There is just air coming out of facets and fixtures when running on the pump (pump is running) and the potable water tank. Water Tank is full, tank drain is closed and fill cap is tight and tanks vent is open. We are not connected to city water. This is our first trip of the season after coming out of winterization storage. Now end of last year I installed a winterization valve and tube fitting to accomadate winterization between the particle filter and the pump inlet. It functioned correctly drawing up the water antifreeze into the system. I confirmed the winterization valve was in the correct position for trouble shooting but removed it to allow easier trouble shooting.
Troubleshooting Steps:
We cleaned out the particle filter
Blew air into line from pump in to water tanks and that's seems clear.
Checked that all visible connections are tight.
Checked pump by using short tube connected to pump inlet and water jug indeed pumps water.
Opened Pump and internal switch works and no visible damage inside the diaphragm #Shurflo 4900-201 water pump.
I welcome any suggestions, system diagram included.
Thank You
Name:	Airstream Water System.jpg
jet2test is offline   Reply With Quote
Old 05-19-2025, 12:28 PM   #2
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
Sounds like you might have an air leak in the intake side of the pump, which is usually due to a loose connection or the screen filter isn't firmly closed.
Richard
11018
1994 Excella 25 'Gertie' Follow the build on Gertie!
1999 Suburban LS 2500 w/7.4L V8 'Bert'
1974 GMC 4108a - Custom Coach Land Cruiser 'The Bus' (Sold)
richard5933 is offline   Reply With Quote
Old 05-19-2025, 06:19 PM   #3
Thanks Richard, I checked then replaced the particle filter and rechecked all of my connections. Still no joy. When I put my hand over the running pump intake I thought the suction felt weak. I suppose my pump could be damaged inside beyond what I could see and inspecting it? Might be new pump time $$. I appreciate your suggestions.
Old 05-19-2025, 07:11 PM   #4
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
Check the seal on the filter
I agree with Richard that it could be a leak. While servicing my filter, I did not notice the o-ring seal had fallen off when I removed it. I had no suction afterwards. I retraced my steps and found the o-ring on the floor next to the pump. After replacing it, the pump primed and everything worked.
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
jeffmc306 is online now   Reply With Quote
Old 05-19-2025, 10:45 PM   #5
1994 25' Excella
If you think that the pump might be bad you might be able to find a rebuild kit for that pump online. If you do rebuild it and save it as a spare and then install a new one.
Pumps are low-cost enough that it's not worth taking the chance of it crapping out during a trip.
Of course, double and triple check for leaks first. You might be able to pull the pump from the motor and see if you have a bit of debris in there causing an issue.
Richard
11018
Shurflo 4008 water pump is not pumping water RoanCi2015 Water Heaters, Filters & Pumps 2 09-07-2024 12:07 PM
water pumping back to street mmette00 Fresh Water Systems 5 05-13-2013 07:31 AM
Pumping anti-freeze thru water lines FredV Winterizing, Storage, Carports & Covers 39 10-28-2012 09:35 AM
Water pump not pumping Isadora Water Heaters, Filters & Pumps 5 05-06-2008 07:49 PM
fresh water tank level and pumping Lumatic Fresh Water Systems 8 12-24-2007 05:51 PM
