RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 10-30-2020, 11:20 AM   #1
2019 30' International
Livingston , Texas
Water Pump Replacement
I have a 2019 30ft International and the water pump sucks! It was replaced once because the backflow valve failed and kept filling up my fresh water tank. The second one isn’t any better. Every time I use it the problem starts again and I have to run the pump with and without city water to TRY and get the backflow to close. It took 3 or 4 attempts over the course of 2-days to get it to stop!
Honestly, I think the Surflo is a piece of crap for such an important piece of equipment in a self-contained ‘home’.
It’s also incredibly LOUD and takes a few minutes to purge the air every time I move. It’s either the pump or Airstream’s installation design is at fault. I have ZERO skills in this are so no idea on what to do next.
Any suggestions on a different pump altogether and NOT Surflo?
Current: Shurflo model 4008-101-A65
Flow: 3 gpm
Serial #: 931268
Thanks!
Dan
djp1162 is offline   Reply With Quote
Pump doesn't turn off and it doesn't pump water either. I don't know what to do! Melimelo Fresh Water Systems 10 05-25-2018 02:39 PM
Hooked up water in winter and can't get water pump to pump water mrpettit Water Heaters, Filters & Pumps 8 05-06-2015 07:46 PM
Pump in RV Antifreeze Downstream from the Water Pump? KJRitchie Winterizing, Storage, Carports & Covers 6 01-09-2015 02:18 PM
air pump vs water pump kamo Water Heaters, Filters & Pumps 22 02-27-2008 03:01 PM
68 water pump-should the pump cycle? Boondocker Water Heaters, Filters & Pumps 8 08-06-2006 11:11 AM
