I'm redoing the plumbing in my newly baught airstream. When I use hot water, will the pump pull water all the way to the back where the water heater is? Thanks!
1976 25' Caravanner
Campton
, New Hampshire
The pump should only be pulling water from the tank to the pump , after that it is pushing . If it is working properly it should feed everything including the shower , both hot and cold .
Right. My pump puts out about 40 psi. This gives plenty of water thru the whole coach. Unless "Mister Stupid" forgot to put the plug back in the city water connection.
