Old 05-09-2023, 02:45 PM   #1
vonherrmanna's Avatar
Irondale , Alabama
Water Pump Question
I purchased a 1999 AS Excella 31’ travel trailer a couple of years ago and have been slowly working on it for my retirement. It’s in good condition, and most of the stuff works. I’ve recently been focusing on the plumbing fixing leaks and other issues. When I connected a water supply to it, I get water to all areas. After filling the freshwater tank, I removed the other source and turned on the pump. I can hear the pump running, but there’s no water being fed to the interior faucets. I feel the problem is the pump, but not sure. Is there a switch to go from hose to tank supply? Anyone had this issue?
vonherrmanna is offline   Reply With Quote
Old 05-09-2023, 03:12 PM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
I would guess your pump has lost its prime or the strainer cap is leaking. You can kill two birds with one stone. Remove the strainer cap and make sure the o ring under the cap is there and in good shape. While you have the cap off, pour a little water in the strainer to prime it, then replace the cap. I also find it helpful to open a faucet when turning on the pump after the water system has been dry.
CRH is offline   Reply With Quote
Old 05-09-2023, 03:13 PM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
No switch, you can run the pump with city water if the city pressure is low.
Your pump might not be able to self prime, a sign of an aging pump. There also might be a valve between the tank and the pump, sometimes installed as part of a winterizing kit.
Richard
Old 05-09-2023, 06:56 PM   #4
2017 25' International
West Lake Hills , Texas
Replace the pump. Replace the strainer. Use the silencer kit. Add an accumulator.
Fungus is offline   Reply With Quote
Old 05-09-2023, 08:19 PM   #5
Irondale , Alabama
Thank you! I’ll check those items.
Old 05-09-2023, 08:19 PM   #6
Irondale , Alabama
Thank you!
Old 05-09-2023, 08:20 PM   #7
Irondale , Alabama
Old 05-10-2023, 07:39 AM   #8
Irondale , Alabama
Thanks!
Old 05-30-2023, 07:14 PM   #9
Irondale , Alabama
I replaced the pump and strainer. The system works now. I plan to order the silencer kit and the accumulator. Do these additions fix the vibration issue that happens as the system builds pressure after shutting off the faucets? Or do I have a new issue?
Old 05-30-2023, 08:20 PM   #10
Silencer kit will reduce the vibrations but not necessarily eliminate them. Accumulator will reduce cycling or throbbing when using a trickle of water.
Old 05-31-2023, 06:11 AM   #11
Irondale , Alabama
Thank you again. I’ll get and install those items, and keep you posted.
Old 05-31-2023, 04:28 PM   #12
Steamguy's Avatar
2019 27' International
Washougal , Washington
Also, watch the hoses to/from the pump when it's running, since you have things already opened up. Often the pump vibrations are transferred to those hoses, and if they're tapping against anything, there's another source of noise. Hardware-store pipe insulation (I've heard of using pool noodles, also, but they're not as soft) on those contact points will go a long way to silencing noise.
Steamguy
2019 International Serenity 27 FB with unsuccessful turboencabulator mod
"Live, Laugh, Love"
Click here to go to my blog: I try to add wisdom, not noise.
Steamguy is offline   Reply With Quote
Old 06-01-2023, 01:15 PM   #13
Irondale , Alabama
I’ll pay attention to that. Thank you.
Hooked up water in winter and can't get water pump to pump water mrpettit Water Heaters, Filters & Pumps 9 08-11-2023 09:52 AM
Cleaning Water Filter on Water Pump - question PatLee On The Road... 2 12-26-2020 09:46 AM
Pump doesn't turn off and it doesn't pump water either. I don't know what to do! Melimelo Fresh Water Systems 10 05-25-2018 01:39 PM
air pump vs water pump kamo Water Heaters, Filters & Pumps 22 02-27-2008 02:01 PM
68 water pump-should the pump cycle? Boondocker Water Heaters, Filters & Pumps 8 08-06-2006 10:11 AM
