Old 03-15-2025, 04:41 PM   #1
2019 22' Sport
Iola , Texas
Water pump plumbing
Just had our water pump replaced and when we got home noticed the shut off valves to the left of the pump are at a right angle ( which to me indicates they are off). I am pretty I don't want to run the pump in.case it runs dry.
Thanks to all the Streamers out there!
IronMaiden is offline   Reply With Quote
Old 03-16-2025, 07:44 AM   #2
Mollysdad's Avatar
Is that the Water Heater Bypass?
I had a similar issue and the service tech had turned off the hot water. (So the tank doesn't drain when disconnected from pump). So I was on a two week trip with no hot water. Fortunately, I was able to reach the valve and open it up. Next time I'm cutting a hole in the closet floor so I don't have to be a pretzel to reach the valve. It was hard to turn.
Name:	Airstream water pump 1.jpg
Mollysdad is online now   Reply With Quote
Old 03-16-2025, 10:08 AM   #3
2019 22' Sport
Iola , Texas
Thanks! We're on city water at this time and the hot water is working fine. I looked at the Airstream parts manual and it was clear as mud. In our 22 ft Bambi the valves are pretty easy to get to. I'm just reluctant to cause any other issues by turning them parallel to the pipe.
Old 03-16-2025, 11:31 AM   #4
1988 32' Excella
Robbinsville , New Jersey
I don't see water heater in picture so doubt they are for bypass.
Are they low point drains? I would expect the red line to be hot water, not connected to pump.
You could have someone outside looking under that part of the trailer and open one at a time and see if water comes out.
Old 03-16-2025, 12:11 PM   #5
2019 22' Sport
Iola , Texas
Thanks! We'll try that
Old 03-17-2025, 10:16 AM   #6
2019 22' Sport
Iola , Texas
Turns out they were the low point drains. Thanks everyone for your help!
Old 03-17-2025, 10:22 AM   #7
1988 32' Excella
You're welcome, glad we could help and thanks for reporting back.
Hooked up water in winter and can't get water pump to pump water mrpettit Water Heaters, Filters & Pumps 9 08-11-2023 09:52 AM
Water pump plumbing diagram. Serf27 Plumbing - Systems & Fixtures 29 10-05-2022 11:04 PM
Plumbing check- Water Pump blew water YoMoHo Fresh Water Systems 5 06-21-2013 12:35 PM
68 water pump-should the pump cycle? Boondocker Water Heaters, Filters & Pumps 8 08-06-2006 10:11 AM
need plumbing map for water pump silverbullet Water Heaters, Filters & Pumps 1 09-22-2002 09:13 PM
