04-06-2013, 09:00 PM
1978 31' Sovereign
Colorado Springs
Water pump has a slow leak?
My 78 sovereign still has the old style belt driven water pump and is seems to be seeping a little bit from somewhere cause thebsubfloor is wet around it after it has been running. Are there gaskets that need to be checked/replaced or am I miles ahead just replacing the old girl? I'm in the middle of a camping trip as I discovered this...is there anything I can do to hedge my situation right now?
Thanks all!
Stream on
04-06-2013, 09:14 PM
1974 Argosy 20
Kooskia
, Idaho
The old Par pump stile with a belt drive is sturdy and reliable, but (in my opinion) does not pump much water. Parts are available, but somewhat hard to find and quite expensive. I have had many Airstreams and wound up replacing the Par pumps in each one of them. My preference is Flo Jet, but the more common one is Sure Flo. Depending on which model you pick and where you get it, the normal ones are $50 to $90 and the fancy speed regulated ones are in the $150 to $200 range. Again, my opinion is that the fancy ones are not worth the extra money, although they are good pumps.
So, rebuild your 35 year old pump or replace it with a newer one. Cost to rebuild is going to be about the same as a new pump of a different type.
As Snoopy said, when he was head beagle of the Puppy Farm: Decisions, decisions, I have made 100 today, and most of them were probably wrong.
04-06-2013, 09:42 PM
2012 28' International
New Orleans
, Louisiana
I used the one below on my boat and would use it on my trailer if I needed a replacement. The Par pumps vibrate and are noisy. I tossed 2 out a few months ago.
Flojet 03526 144A Triplex Diaphragm 3526 Series Automatic Water System Pump : Amazon.com : Automotive
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
04-06-2013, 10:32 PM
Maniacal Engineer
Lopez Island
I replaced our original Par pump w/ a ShurFlo - much quieter, and provides more water at higher pressure.
You may have a leaking diaphragm in the Par pump. This is typically the problem if the pump doesn't keep cycling on. You may be able to jury rig a repair with a piece of rubber gasket or truck inner tube.
- Bart
04-06-2013, 11:24 PM
The shurflo Revolution pump is great, $70 bucks, great consistent pressure.
04-07-2013, 01:34 AM
1978 31' Excella 500
Genoa
, Nevada
Thanks all!
Stream on
The diaphragm has probably developed an aneurism. Repair with a piece of inner tube or maybe a little thicker rubber, I think it mics at .060. I used some roofing rubber off a roof rebuild. Check that you got all the screws out before you try to force the pump apart, there's a couple screws hiding, it should come apart without much force. The diaphragm pump itself is held together with a screw bolt I think, take that apart, sandwich your inner tube between and put it back together. Haven't had a leak on my rebuild I did in '08 yet. Price is right, hardest part is getting to the back screw holding the pump down to the floor.
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
04-07-2013, 07:16 AM
1974 Argosy 26
Morrill
, Nebraska
I just bought a NSTAR 3 GPM @ 60psi pump from Northern Tool. The Northern tool part # is 2683061.
I use the pump to transfer grey water from the original 12 gallon tank, to a 21 gallon auxiliary tank I installed over the axles. I now have 33 gallons of GW capacity, without tearing out the floor or belly pan. Or dealing with a portable tote. Only lost 4 cubic feet of cabinet storage. Which I made up for in other areas of the coach.
The pump is really quiet and looks well built. It cost $90.00.
