06-04-2023, 11:23 AM
1992 34' Excella
Salem
, Virginia
water pipe broken
Pipe broke in water pump area at an inline filter.
Is replacement filter available anywhere? Like most things Airstream, extremely difficult to access so don't know if one of the newer filters will fit.
ALSO, I believe all lines are 1/4" ID. Local RV shop did not recognize the filter and had no 1/4" fittings. Suggested Lowe's.
Pictures attached. I don't know what he first one is. two red wires. Possibly Autofill (which doesn't work)? Readable on filter - "Water Flow with arrow" - right to left in picture. "Ambient temperature". Can't read Company name in red. Maybe "KG86042" and "AFP70268" at bottom.
Several connectors, some appear to be compression.
ANY suggestions greatly appreciated.
06-04-2023, 02:33 PM
1995 25' Excella
xxxxx
, xxxxxx
Your trailer has polybuyelyne plumbing. If you need to replace or add new pipe, like Pex, you will need a transition adapter. You can get them in push to fit Sharkbite style or crimp fit style.
06-04-2023, 04:25 PM
1992 34' Excella
Salem
, Virginia
I'm certain that little in line filter has been there for the entire life of the trailer. It is maybe 20% clogged, which doesn't leave much in a 1/4" pipe.
Should I worry about not replacing it?
06-04-2023, 04:37 PM
1995 25' Excella
xxxxx
, xxxxxx
My filter doesn't look like that. My trailer has a Shurflo strainer type. It has a 1/2" inlet and outlet. Mine is attached with hose clamps.
06-04-2023, 04:51 PM
2010 30' Classic
Warren
, Manitoba
I don't think that is original Airstream install! As mentioned above, replace with a new filter, available many places and use Pex pipe with Sharkbite transition fittings to attach to your old Polybutylene. Not a big project!
ACI #7394
2012 GMC 2500 HD Duramax Denali
2010 Classic Limited 30' ,1994 Excella 34'
1987 Limited 34', 1976 31' Sovereign, 1976 Argosy 22' Gone to new homes
Hensley Hitch
06-05-2023, 06:57 AM
1992 34' Excella
Salem
, Virginia
Thank you. I think I can get 1/4" sharkbites at Lowes. I hate to put them into polybutelene but no real access to any length of it to replace.
While I'm in there, can anyone tell me what the device in the first picture is?
"Not as big project." To quote my deceased Airstream guru - "I need to hire a Little Person with 4' long arms and 2 elbows in each arm. I could charge Flat Rate Book rates and make a million dollars."
06-05-2023, 07:22 AM
2009 27' FB Flying Cloud
1982 31' International
1991 35' Airstream 350
Jay
, Oklahoma
From the photos, I'm not sure that's a filter. It looks like a one-way check valve.
From the solenoid valve I see in the photos, is there by chance a switch near the water pump power switch/control panel labeled "Auto Fill" ? This was a neat feature on that era of rigs that when activated fills the fresh water tank to 3/4 full when turned on and the the trailer is connected to a fresh water source, then turns off automatically.
The others are right, the gray plumbing is poly, but newer pex can be intermingled with it via sharkbite fittings to make repairs with no trouble.
Best Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud;'82 31 International
'91 350 LE MH; '21 Interstate 24GT
06-05-2023, 08:23 AM
1992 34' Excella
Salem
, Virginia
Yes there is an autofill switch. Hasn't worked since we bought trailer but I may be doing something wrong because it was in "better than showroom" condition when we bought it. Before the owner put it up for sale, his wife had him make a trip from Detroit to the mothership to replace the stone guards because "they had dents in them."
Off to Lowe's. I've depended on them for years for house stuff. Mainly because of their return policy. Not sure what fittings? Just buy a bunch and take back what you didn't need.
Thanks again to all for your help.
06-05-2023, 09:23 AM
2010 30' Classic
Warren
, Manitoba
You are correct on the autofill line! My 1987 Limited had that and it never worked. I finally checked it out one day and everything had been removed and capped off. PO said that it had misfunctioned one time and he removed it. That does look like a check valve, but the hose clamp makes me think that somebody other than factory has been "working" on things. That is a solenoid valve in the picture. If you have no leaking water, best to leave alone!
ACI #7394
Hensley Hitch
06-05-2023, 11:05 AM
1995 25' Excella
xxxxx
, xxxxxx
I believe you will need 1/2" Sharkbite fittings, not 1/4"
06-05-2023, 01:07 PM
1992 34' Excella
Salem
, Virginia
The auto fill valve is 1/4" and Lowe's doesn't have any sharkbite type connectors to get me to 1/2". So going old fashioned way with reinforced poly tubing and barb/clamp connectors.
06-05-2023, 08:32 PM
1992 34' Excella
Salem
, Virginia
Half an hour to install three fittings. An hour and a half for the last one. But it is DONE!
Thank all y'all for the information.
