Old 06-04-2023, 03:50 PM   #1
2000 19' Bambi
2018 23' International
Auburn , Maine
Water heater mystery—2018 International
We have a 2018 23fb International Serenity with a mystery water heater problem. (Atkinson electric/propane WH.) The water heater fires up and to all appearances heats up. But we’re not getting hot water out of the faucets. It seems to start to get a bit warm, but then cools again.
The winterize valve is not in the winterize position. It tested fine a month ago when I did a spring re-check of everything, though I did not run it very long when I tested it.
Any idea what might be going on? The only thing I can think of is that the winterizing valve is not working properly, so the WH is really being bypassed, but that really doesn’t seem likely to me.
The propane burner ignites, and after a bit the exterior of the WH gets warm to the touch, so I don’t think the problem is the WH itself.
Film Maker,
Photographer,
Lover of Mid-Century Design
especially our Airstream
blog: https://airstreampictures.typepad.com
FilmGuy is offline   Reply With Quote
Old 06-04-2023, 06:11 PM   #2
The Aluminum Tent 3
pcskier's Avatar
2014 23' Flying Cloud
Park City , Utah
Mixing valve could be clogged
which is common. You can remove it to clean the screen and soak in CLR or vinegar. It is located near the bypass valve. Click image for larger version
pcskier is offline   Reply With Quote
Old 06-04-2023, 06:22 PM   #3
ZOZ
ZOZ's Avatar
2018 23' Flying Cloud
Peru , Illinois
The Mixing Valve Chronicles
https://www.airforums.com/forums/f44...ve-177432.html
zoz
Cindy & Randy
2018 AS Flying Cloud 23FB
2018 GMC Sierra Denali 4x4 6.2L
ZOZ is offline   Reply With Quote
Old 06-04-2023, 06:45 PM   #4
2000 19' Bambi
Auburn , Maine
Originally Posted by ZOZ View Post
Thanks, guys. That looks like the culprit. Given the amount of trouble it seems to cause, it seems to be a less-than-helpful solution to its intended problem.
Film Maker,
Photographer,
Old 06-04-2023, 08:10 PM   #5
The Aluminum Tent 3
pcskier's Avatar
Park City , Utah
Have you tried in both electric and gas modes? If only electric, outside chance a bad element. It’s worth a test on gas to make sure. You also can CAREFULLY pop the pressure relief valve to see if very hot water comes out. Standing well to the side and wearing f gloves. This will prove that the water in the tank is being fully heated or not.
I have never had a problem in five years, including the past three full time with the heater on electric mode 24/7. So who knows, water is hard here as well. Though I’m sure i have now jinxed myself.
Old 06-04-2023, 10:11 PM   #6
Ron Glow's Avatar
2018 27' Flying Cloud
Haubstadt , Indiana
In my experience, I have removed the mixing valve to clean it and also tried “tapping it” with a plastic hammer without removing. That may jar some buildup loose from the screen inside the valve. Usually you also will have lower water pressure if the screen is clogged, since it is reducing overall flow. Please use restraint if “tapping”. Others may object, but it does work sometimes.
Ron
Ron Glow is offline   Reply With Quote
Old 06-05-2023, 07:33 AM   #7
2021 19' Bambi
Latham , New York
A problem I had was my propane hot water heater output temperature started dropping from the setpoint. The hot water heater was firing up and the water flow was normal but the output temp kept dropping a couple degrees over a few days of use. The stove and furnace were working normally.
After much anguish (I'll spare the details), I played with the small set screw on regulator for the propane tanks, opening it a fraction and Viola/back to normal!
WhatNext is offline   Reply With Quote
Old 06-05-2023, 11:24 AM   #8
2019 23' International
Boulder , Colorado
Has anyone tried using a slightly coarser screen or leaving the screen out entirely from the mixing valve? It might involve cleaning the screens at the faucet heads more often but that is easier.
coerector is offline   Reply With Quote
Old 06-05-2023, 02:17 PM   #9
HENDERSON , Kentucky
Solution
Exact same trailer. Had this same problem when we got to our campsite in Smokies NP. I knew heater worked, as I tried it at home, but as we tried it in Elkmount, had the slightly warm, then cold issue as described above.
After suffering a week with this, returned home, did a little research on this forum , and felt it must be that the screen on the anti-scald valve pictured above in this thread must be the problem.
Unhooked the lines from it, and with difficulty unscrewed the valve & fitting from the tank. (Fitting going into tank was very, very tight)
Upon removal, could clearly see crystals clogging the screen. Cleaned it & valve, reassembled everything & tested, working perfectly again.
I cannot prove it, but I believe my cleaning out the fresh water system might have broken loose the crystals from inside the tank causing the clog.
stwaller is offline   Reply With Quote
Old 06-07-2023, 11:18 AM   #10
The Aluminum Tent 3
pcskier's Avatar
Park City , Utah
Clogged mixing valves and faucet screens are more common after dewinterizing or when filling an empty water system prior to a trip if the water was drained. The force of the cold water filling the empty water heater can loosen up mineral deposits that then find their way downstream.
Giving the water heater a good flush with a Camco flush wand at least annually is a good idea depending on water hardness. I deal with very hard water and do it once or twice a year. The amount of mineral materials that break loose and drain out is amazing...like a pile of hail on the driveway. I follow that up with a white vinegar soak of the tank overnight to dissolve or loosen stubborn buildup, then flush thoroughly again, where even more comes out. There are Youtube videos on how to do that process. I draw vinegar in to the water tank via the antifreeze valve behind my water pump. 3 or 4 gallons.
Water heater mystery Runaground Water Heaters, Filters & Pumps 1 04-23-2018 07:45 AM
Water heater mystery drain tube? ViewRVs Water Heaters, Filters & Pumps 10 06-18-2016 12:06 PM
Mystery leak from old water heater SuzairMcD Plumbing - Systems & Fixtures 3 11-20-2012 10:32 AM
Replacement Water Heater Mystery seventythree Water Heaters, Filters & Pumps 8 03-09-2010 06:53 AM
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 08:17 AM
