Water heater issues
Hi folks-
I own a 1994 Airstream Excella 1000. It has a standard Atwood 6 gallon water heater. The previous owner what looks like a home style thermostat control.
Because this is an add on I'm concerned it may be causing the water heater to overheat to the point where the pressure release valve activates and leaks water.
I have replaced the gas regulator and I have a new ECO Kit that hasn't been installed.
If you look at my attached photo you will see the add on to the left side of he photo.
Thanks in advance!
Mark
