02-26-2022, 09:35 AM
2023 27' Globetrotter
Loda
Water Heater faults frequently
My water heater faults frequently:
On propane: The heater turns on fine, heats the water and cycles through once or twice, then faults.
On electric: It either faults immediately or after 30 minutes of operation.
Both scenarios get us warm showers in the morning, but I can't help but want to fix the problem.
New circuit board?
Thanks for any help.
Dave
02-26-2022, 09:44 AM
2007 30' Classic S/O
Somewhere
, South Carolina
Dave,
Is this a common tank type or some other type water heater? Model info can verify.
If a tank type care to try disconnecting the harness to board and very lightly clean the board terminals maybe use a pencil eraser and try again.
Gary
02-26-2022, 10:41 AM
Loda
Gary - it’s a Dometic 6 gallon. Thanks for the suggestion. I will give it a shot.
02-26-2022, 10:55 AM
2020 23' Globetrotter
Savoy
Our 2021 Gt23 water heater cold to barely warm water. So I replaced the igniter board with a elephant circuit board. But that didn't fix the problem. Water temp would vary from 120 deg to 90 deg. So I took the mixing valve off. The fine mesh screen was covered with a white residue. So we purchased an a new mixing valve. Its been to cold to fill the water system to make sure that its fixed. I cleaned the old mixing valve with apple cider vinegar and will put it in our spares totes.
02-26-2022, 11:29 AM
Somewhere
, South Carolina
6 gallon Dometic, very common and very fixable. does everything look normal, no burns, heat staining etc marks on exterior?
02-26-2022, 11:45 AM
2019 27' Globetrotter
McHenry
Dave, we had a 2018 FC23FB and the water heater faulted on gas but worked on electric. Turns out this is a common problem and Atwood updated the board to a new design (I think Atwood is owned by Dometic now).
Check to see if you have the old or new board. Any chance you’re within the 3 year factory warranty? If so, contact the dealer or Jackson Center. They may just send you the part.
Good luck!
-Jeff
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
02-26-2022, 01:11 PM
Loda
Everything else looks fairly normal.
02-26-2022, 02:03 PM
Somewhere
, South Carolina
In your AS owners manual pack, do you have one for the Dometic unit? This is a Dometic water heater manual but doesn't have troubleshooting. But they show that if you go to Dometic website you can access further info. https://www.dometic.com/assets/43/37/93755_64337.pdf
02-27-2022, 10:31 AM
2012 25' Flying Cloud
Berlin
, Maryland
I had a similar problem and had it checked by a tech. The board was good. I did have the R&R fuse replaced and also the thermostats.. The fuse was good however old it is working fine now
05-12-2022, 09:58 AM
Loda
New circuit board?
Dave
I have replaced my circuit board with the Dinosaur UIB 64. Looks cooler, but no change in operation.
I get plenty of hot water when I need it, and we do not run our water heater continuously, but I would like to find the problem.
Any other suggestions??
Thanks again,
Dave
05-12-2022, 10:17 AM
Somewhere
, South Carolina
I'd be looking at the ECO and actual T-stat both are on the outside of the tank. The ECO Emergency Cut Off is a Captain she's gonna blow! preventer. If its open when it shouldn't be it's like the plug has been pulled gas or electric. The T-stat is just that a T-stat.
Do you have a multimeter? And tackle one heat source at a time, I'd look at getting the gas side going because its easy to see/hear the flame.
05-12-2022, 08:16 PM
Loda
Thanks. I do have a multi-meter. I’ll give it a shot!
