Old 01-20-2019, 03:13 PM   #21
ObviouslyKnot
james.mileur's Avatar
KAILUA , HI
Drain plug under water and pressurized regardless of an air cushion in the top of the water heater or not. Don't understand the connection.
No pun intended.
James Mileur, HY80-2-Al,
2017 Classic Twin, 2016 RAM 3500 Megacab, ProPride hitch
james.mileur is offline   Reply With Quote
Old 11-04-2021, 05:05 PM   #22
2017 25' International
san diego , California
Atwood water heater drain plug issue - 2017 AS Int'l
I purchased two drain plugs from the local hardware store at $1.76 each.
I've replaced the WH drain plug but it still drips. I wrapped the plug w/ teflon tape in hopes to prevent the drip but to no avail.
So, I bought two plugs from Amazon for $10 which have the same exact model no. as recommended from AS thinking they were better. When I received them they were exactly like the drain plugs I purchased from the hardware store for $1.76 each. Someone's making a tidy profit from these... lol. Don't buy them from AMAZON.
I did notice that the drip is more prominent when the water is connected to the campsite water and under pressure.
Any suggestions?
marki is offline   Reply With Quote
Old 11-04-2021, 05:36 PM   #23
2018 30' Flying Cloud
Springfield , Ohio
You will probably have better luck using pipe dope. It generally gives a better seal than teflon tape especially with problem joints.
2018 Flying Cloud 30RB + 2020 Silverado 2500HD Duramax/Allison
tbrowne is offline   Reply With Quote
Old 11-04-2021, 06:18 PM   #24
"Cloudsplitter"
2003 25' Classic
Originally Posted by okstreamer View Post
Another plumber here, and I agree with previous post, get rid of the plastic plug, it has different thermal growth characteristics than the surrounding metal. My plastic plug started leaking and I just replaced with a brass plug and small amount of pipe dope . No more leaks.
YEP... I used a valve that stays put.
Water heater dripping at outside access panel Hikesail Water Heaters, Filters & Pumps 18 05-08-2020 12:19 PM
Water dripping from copper drain pipe.... Mx468 Water Heaters, Filters & Pumps 9 08-31-2018 02:10 AM
Atwood water heater dripping mmich21 Water Heaters, Filters & Pumps 10 12-01-2016 02:18 PM
water dripping from hot water heater access panel groundhogy Water Heaters, Filters & Pumps 5 06-01-2015 10:21 AM
Grey water indicator is yellow even tho drain is open CalamonTin Our Community 2 05-25-2014 07:51 PM
