Old 01-20-2020, 11:04 AM   #1
2020 25' Flying Cloud
Oak ridge , Tennessee
Water heater bypass valve
Recently purchased 2020 airstream flying cloud fb twin 25 ft. Water heater bypass under twin mattress with small round hole to access. Almost impossible to reach and turn. Anyone have any ideas to make it a simpler process?
Sewall is offline   Reply With Quote
Old 01-20-2020, 01:56 PM   #2
2017 28' International
Jim Falls , Wisconsin
Take out the wood panel the mattress rests on. Should be pretty easy.
Daquenzer is offline   Reply With Quote
Old 01-20-2020, 02:07 PM   #3
Long Island , New York
Make that hole bigger.
OTRA15 is online now   Reply With Quote
Old 01-20-2020, 03:22 PM   #4
daleyocum's Avatar
2018 25' Flying Cloud
Portland , Oregon
We winterize using just using compressed air so haven't needed to access that valve. We just pour some antifreeze down each drain to protect the P traps and call it a day after blowing out all the water with air. If you are going to use antifreeze, though, you would need to access that valve. Antifreeze is more work to load into the trailer in the winter and then flush in the spring.
Maybe antifreeze is required in more extreme climates, though. This is a very hot debated topic which you can spend hours researching. All I can say, in Portland, OR, air has worked fine for us.
daleyocum is offline   Reply With Quote
Old 01-21-2020, 12:20 PM   #5
1996 25' Excella
Tillsonburg , Ontario
Can you make up some sort of tool to grip the valve handle and turn it from outside the hole?
If you are blowing out the system how do you remove water from the HW tank. Usually the by pass is opened and inlet out let valves are closed before blowing out. (maybe your valve does all of that in one single vale...not familiar with the new trailer set up.) otherwise you keep pushing water mixed with air from the tank into the HW piping. The HW tank is then drained by removing the drain plug. A little bit left in the tank is of no consequence, but a little water in the piping and taps can be a problem
JCW
JCWDCW is offline   Reply With Quote
Old 01-21-2020, 12:58 PM   #6
2018 25' International
Slidell , Louisiana
It is often described as a bypass valve, but it is actually a cold water inlet to the water heater. In "bypass" cold water travels through the mixing valve but does not enter the tank itself a check valve prevents water from back flowing into the tank when the inlet is closed. A drain valve is accessible from the front CS outer compartment to first drain the tank prior to closing the subject inlet valve. I agree the inlet valve is a bit hard to get to... I'm waiting to hear if anyone has rigged up something they like.
Brian
Old 01-21-2020, 02:19 PM   #7
Gulliver72's Avatar
2015 25' FB Flying Cloud
Barnstable , Massachusetts
Valve tool
I too have struggled with that valve. Iím looking to make a tool (as suggested in a previous post). It needs to have an inside diameter of 1Ē, and have opposing slots of about a 1/2Ē cut in it. It should be about 18Ē long and have a handle of some sort at the top end. Thatís the design, I just havenít figured out what to start with. Iím a woodworker, not a metalsmith. Any ideas?
Gulliver72 is offline   Reply With Quote
Old 01-21-2020, 03:20 PM   #8
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
I have made such things out of PVC pipe, which is easy to cut, add handles with more pipe and so on. Just buy a few feet of the right size stuff and go from there. I have done that with my natural gas shutoff at my grill so I do not need to get down on the ground to shut it every time.
Larry
lsbrodsky is offline   Reply With Quote
Old 01-21-2020, 03:25 PM   #9
Slidell , Louisiana
Perfect Larry. You're the man! I've got this.
Brian
Old 01-21-2020, 08:39 PM   #10
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
I put a 10" marine deck plate in the floor of my closet so I could access the valve and water pump connections for winterizing. Airstream looked at it as a desired improvement, but I don't know of any installed.
guskmg
Old 01-21-2020, 08:57 PM   #11
Life is a Highway's Avatar
2019 25' Flying Cloud
2021 30' Flying Cloud
Lady Lake , Florida
Ditto
Ya beat me to it. Ditto on the PVC
Larry
Life is a Highway is offline   Reply With Quote
Old 01-22-2020, 07:21 AM   #12
1996 25' Excella
Thanks for the update
JCW
Old 01-22-2020, 09:31 PM   #13
2019 25' International
Washington , Washington, D.C.
It is difficult to access. Look at it in beam of a flashlight to fix in your mind, then immediately reach for it and turn (takes a firm touch). I've had to turn it 3 times now when winterizing and it's much easier to access/turn for some reason. "Practice makes perfect"?
PatLee is offline   Reply With Quote
Old 01-29-2020, 01:21 PM   #14
International Grey Nomad
1999 35' Cutter Bus Diesel Pusher
Bulahdelah , NSW Australia
Must be time for Mr Airstream to post noting that the unanimous concerns have been noted and the factory directed to come up with a sensible solution
Tony LEE
International Grey Nomad.
Travel photos at Picasa Album
Trip map at Spotwalla
Tony Lee is offline   Reply With Quote
Old 01-30-2020, 05:24 AM   #15
Farwell , Michigan
Remove the mattress, and lay down between the camper wall and the hole. This position allows you to reach down the hole and easily adjust the valve.
smvanhoose is offline   Reply With Quote
Old 01-30-2020, 07:38 AM   #16
eagletoo's Avatar
Going to see if JC can cut a larger hatch to make access easier while standing on my feet.
Bruce
2021 Ram 1500 Laramie - 5.7L Hemi eTORQUE
2022 Globetrotter 23FBT - On Order. Due in October.
Airstream Club #2600
Iíd rather be camping is an understatement!
eagletoo is offline   Reply With Quote
Old 01-30-2020, 08:30 AM   #17
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
Our water heater is under the driver’s side rear twin. Besides the access hatch the plywood from the bed can be removed for access if needed. A hatch could be added there very easily.
Ray B.
Adventure.AS is offline   Reply With Quote
Old 02-09-2021, 11:15 AM   #18
BobAndStella's Avatar
2017 25' Flying Cloud
Monterey , California
Why does Airstream make it almost impossible to winterize (at least some of) their travel trailers?!
Has anyone tried something like this:
https://www.homedepot.com/p/30-in-St...0111/312012434
BobAndStella is offline   Reply With Quote
Old 02-11-2021, 02:25 PM   #19
Baby Zeppelin's Avatar
2018 28' Flying Cloud
Clayton , Georgia
No, but I did attach a handle extender to one wing of the valve handle so I could more easily operate it. Don't have a photo but it involved drilling a square hole in a piece of aluminum bar stock, such that the hole tightly went over the wing of the handle, then epoxying it in place. Now I move the valve handle over a larger arc, but have more leverage to turn it.
Erik & Carol
Clayton, Georgia
AS: 2018 Flying Cloud 28 "Baby Zeppelin"
TV: 2017 Ford F250 Lariat w/ Blue Ox Sway Pro
AIRForums #126944 WBCCI #1297
Baby Zeppelin is offline   Reply With Quote
Old 02-11-2021, 05:51 PM   #20
RivetED's Avatar
Airstream - Other
Airstream - Other
North Central Texas , USA
Someone from Airstream must have been listening...'19FC25'RBT
RivetED is offline   Reply With Quote
Hot Water Heater Bypass Valve Access donreitz 2009-2015 Flying Cloud 6 02-12-2021 03:54 PM
Location: Water heater bypass valve? Will_Brule Water Heaters, Filters & Pumps 17 10-08-2019 04:06 AM
Water heater bypass valve lucybear Water Heaters, Filters & Pumps 20 10-18-2017 09:09 AM
Water heater bypass valve on Interstate Ext Lounger drguthman Our Community 0 01-23-2017 06:51 PM
Water heater bypass valve Robfike General Motorhome Topics 6 05-11-2014 06:21 PM
