03-01-2020, 06:51 AM
2017 27' Flying Cloud
Fort Worth
Water hammer?
Back in our 2017 FC on our way to the Keys. First use since winterizing. We have hot and cold water and the pump seems to be working fine. However, when we run the faucets or flush the toilet, there is a few second (3-4) long vibration on the opposite side of the trailer from the pump. We have used 20+ gallons of water so that should have gotten any air out of the system and there is no sputtering. I have also run water through the water heater pressure valve, but none of this fixes the noise. Ideas?
03-01-2020, 07:11 AM
2002 25' Safari
Dewey
Hammering is due to air pockets. Have you run water through every valve in the trailer? Outside shower, if you have one, is often overlooked...
Richard
03-01-2020, 08:03 AM
2017 25' International
Niagara-on-the-Lake
, ON Canada
This trick was shown to me by Andy Thompson at Can-Am RV.
The hot water tank works like an accumulator in the system. If the air gap is missing at the top of the tank you will get the water hammer when using the pump. Try letting some water out of the tank by toggling the pressure relief valve to let some hot water out of the tank.
Ray B.
03-01-2020, 08:45 AM
2007 30' Classic S/O
Somewhere
, South Carolina
The T&P relief valve is below the top of the tank right? Wouldn’t the procedure to reestablish the air pocket be to turn water off, turn HWT off, drain HWT completely careful it’s hot water, leave T&P closed, replace drain plug in tank and fill system leaving T&P closed.
03-01-2020, 09:10 AM
2012 25' FB International
Trent Woods
, North Carolina
Yes! The procedure for doing this is even in my 2012 manual, as a cure for a relief valve that is spitting. Have done this for a number of club members over the years. You can lose the air bubble over time, even before the season is over.
Larry
03-01-2020, 10:11 AM
2019 27' Globetrotter
2023 30' Classic
Denver
, North Carolina
Establishing Water Heater Air Gap
From my Dometic GE9EXT water heater manual in a 2019 Globetrotter:
"TO REPLACE THE AIR GAP FOLLOW THESE STEPS:
1. Turn off main water supply (the pump or water hook up source). 2. Let water cool or let run until cool.
3. Open the hot water faucet closest to the water heater.
4. Pull handle of pressure temperature relief valve straight out and
allow water to flow until it stops.
5. Allow pressure temperature relief valve to snap shut; close faucet;
turn on water supply.
6. Turn on water heater and test."
Easy to do, don't forget to let the water in tank cool first. The manual also states that the air gap will go away over time (they don't say how long) because the air will gradually be absorbed by the "expanding water".
Dave S
03-01-2020, 12:18 PM
Somewhere
, South Carolina
Dave S,
Sounds a bit easier than my armchair comment, again RTFM.
Gary
03-01-2020, 01:54 PM
2023 30' Classic
Denver
, North Carolina
GCinSC2
LMAO, In had to look that one up.
Dave S
03-01-2020, 03:18 PM
Somewhere
, South Carolina
Originally Posted by link2dks
GCinSC2
Dave S
Works about 90% of the time the other 10% is blowing in the wind.
Greetings from lower Carolina to upper but in the traffic shadow of CLT Carolina.
Gary
03-01-2020, 03:35 PM
1967 17' Caravel
Pocatello
, Idaho
This thread really made me feel my age: don't understand a single one of these acronyms (textonyms)?.
03-01-2020, 04:06 PM
Somewhere
, South Carolina
Water hammer?
Cerb,
I might be similar age bracket. I remember where I was when JFK was assassinated.
RTFM could be a standard reply for a bunch of queries here.
Read The Friendly Manual
And CLT is Charlotte NC and the area that Dave lives in can have some pretty horrific traffic I-77 has been in near constant construction for long time and driving an Airstream on it will get your attention.
My mom was fluent in shorthand. Not me.
Pocatello traffic is taters and beet wagons or am I off by a bunch of counties.
Don’t forget to use the dipstick and check the height of your water to air interface. JK just kidding.
Gary
03-01-2020, 05:54 PM
2007 22' International CCD
Corona
Sigh. I was a junior in high school when we heard JFK got killed.
Boy, that was a hugely long time ago...
“I used to be young and foolish, now I’m no longer young..”
03-01-2020, 06:34 PM
2018 25' International
Slidell
, Louisiana
Just to be clear so no reader is confused, water hammer occurs in the ABSENCE of air pockets. They are due to shock waves initiated by inertial forces of incompressible fluids when a valve is closed quickly.
Air is compressible and thus when there is sufficient air somewhere in the direct path of the shock wave, the wave will immediately dissipate before it hits a hard stop on the far end of the pipe run and cause the hammer effect. Without air the wave will ring back and forth slowly dissipating.
The fix for water hammer has been described by others which is to get a bit of air into the top of the water heater, as it is the only space in these Airstreams designed to "accumulate air".
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Reduce water hammer
GatorDave |
Plumbing - Systems & Fixtures |
8 |
06-09-2018 05:49 AM |
Water pump / jack hammer
Dan S |
Fresh Water Systems |
6 |
04-08-2007 09:00 PM |
Water Hammer
smily |
Water Heaters, Filters & Pumps |
10 |
02-08-2003 04:18 PM |
Water Hammer
melprice |
10 |
07-30-2002 01:10 PM |
