Old 06-06-2019, 04:26 PM   #1
1981 31' Excella II
Tucson , Arizona
Turn off hot water heater for the Summer?
Is there any reason I should NOT disconnect my hot water heater for the Arizona Summer. I now take full showers with only the 'cold' water & that's even kinda too warm Complete newbie here: should I turn off the LP going to the heater, or simply unplug the igniter...? If I keep water flowing thru but don't heat it, it seems that I wouldn't need to empty, flush out... I'm wasting propane, and creating unnecessary additional heat by having the hwh kick on at night.
I'm not travelling, living in an RV park, and I will not need 'hot' water again until probably November.
Thanks very much!
LynneC is offline   Reply With Quote
Old 06-06-2019, 04:41 PM   #2
2007 22' International CCD
Just turn off the water heater power switches?
Old 06-06-2019, 05:20 PM   #3
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Turn off water heater switch until you need hot water and you get cold water out of the faucet. If water is in the water heater, the ambient air temperature will warm it slightly from whatever you get from CG connection. No need to drain the water heater and using the hot water faucet will keep flushing the system.
Gene
The Airstream is sold; a 2016 Nash 24M replaced it.
Gene is offline   Reply With Quote
Old 06-06-2019, 08:14 PM   #4
Sag Harbor , New York
Well said, Gene and Rich.
Welcome to the forum, Lynne!
We leave the switch off until we need warm/hot water. Ours has a quick recovery time. As Gene suggested, be sure to use the hot water line also at times, to keep the water fresh.
Cheers,
Peter
Old 06-06-2019, 11:00 PM   #5
1981 31' Excella II
Tucson , Arizona
The Switch
Thanks everyone! but... where might this 'switch' be? Inside or outside? I'm not seeing anything like a power switch in either place. 'member, this is a 1981, with I think the original hwh.
Old 06-07-2019, 06:17 AM   #6
Check your owner's manual. There should be be a 12-volt rocker switch, probably in the bathroom. If you don't have a manual, let us know and we can find one online via the Airstream site. Our 1985 Sovereign's switch was above the counter in the head.
Peter
Old 06-07-2019, 11:19 AM   #7
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda , California
I concur
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
WBCCI 9164
*Virtual campfire at https://www.facebook.com/groups/Airs...dictsforAdults
cazual6 is offline   Reply With Quote
Old 06-07-2019, 10:33 PM   #8
1981 31' Excella II
Tucson , Arizona
Found the switch
Doesn't seem a very logical place... in the cupboard sorta below the sink and beside the toilet. Whaaat? Why not in the cupboard with the hwh.
Thanks everyone!
Should longterm boondockers turn water heater off mandolindave Water Heaters, Filters & Pumps 23 06-26-2020 09:09 PM
Hot Water Heater Works But No Hot Water Althea Water Heaters, Filters & Pumps 6 04-16-2016 09:45 AM
How to turn off Kenwood in Dash Display, hot water? Doug454 Sprinter and B-van Forum 5 05-19-2013 05:29 PM
Water Heater Won't Turn Off Landrum Furnaces, Heaters, Fireplaces & Air Conditioning 5 11-12-2012 10:43 PM
Bedroom Lights Don't Turn On/Turn Off and turn back on after a couple minutes. alecg Lights - Interior & Exterior 9 09-01-2010 02:01 PM
