Old 09-25-2023, 10:25 PM   #1
2012 25' FB Eddie Bauer
2009 19' International
Aptos , California
Truma AquaGo tankless water heater reset process
I’ve got an after market Truma AquaGo tankless water heater installed in my 27’ International and it’s great. Occasionally, though, it loses it’s mind if I run out of propane (usually by forgetting to turn on a tank valve). You’ll know this when the little amber light in the round multi-position switch blinks and the water doesn’t heat.
There is a long process described on the Truma site and elsewhere on YouTube that wants you to open taps and run water for up to 15 minutes. I’ve found, however, that all you really need to do is turn the inside switch to off, go outside, open the Truma compartment, flip off the on-off toggle switch inside, wait 30 seconds or so, then flip it back on. Back inside you turn the switch to the heat position, the little amber light comes on, holds steady, and you’re back in action.
brad1 is offline   Reply With Quote
Truma AquaGo Installed 2012FB Water Heaters, Filters & Pumps 24 05-21-2023 08:01 PM
Truma AquaGo Comfort Plus Installation miamipanther Water Heaters, Filters & Pumps 8 02-19-2023 10:34 AM
Truma AquaGo Comfort Door/trim Paint hovr Water Heaters, Filters & Pumps 2 03-28-2022 08:03 PM
Truma AquaGo tankless water heater waninae39 Water Heaters, Filters & Pumps 41 05-06-2019 09:00 AM
Thoughts on adding Truma AquaGo 2017 Classic sbowman 2016 - Current Classic (all lengths) 4 02-23-2018 03:34 PM
