Old 04-07-2021, 09:25 AM   #1
2021 16' Bambi
San Diego , California
Tankless Water heater Leak - 2021 Bambi 16RB
After 3 months and over 20 days uses, I've got a pinhole leak in a copper water line which looks to be coming from copper holding tank for tankless water heater. Only sprays when water pump on. Airstream maintenance extremely backed up and can't drop off for warranty work until mid May; many trips planned before.
Looks like I can access water pump through my closest if I remove some screws and panels. Will Flex seal tape get me by before warranty repair? Any advice on how to access water pump from the rear; the leak is on right side of unit near back. Unable to reach from front access panel.
FunBoss20 is offline   Reply With Quote
Old 04-07-2021, 09:44 AM   #2
JEB
2021 23' Globetrotter
Northern , Illinois
That might work for a temporary fix, but I think you’d be better off using epoxy putty. Neither is a permanent fix, but the putty will likely last longer.
JEB is offline   Reply With Quote
Tankless 2021 Water Heater Life is a Highway 2016 - Current Flying Cloud 3 03-30-2021 07:16 PM
2021 Bambi 16RB - Hot Water shower issues ricko24 Fresh Water Systems 13 03-18-2021 02:07 PM
Bypassing tankless water heater in 2021 Flying Cloud youknowjack Fresh Water Systems 2 03-08-2021 10:58 AM
Hitch and brake controller for 2021 Bambi 16rb Gmca Towing, Tow Vehicles & Hitches 25 10-11-2020 11:15 AM
Under Sink Drawer Extension for 2021 Bambi 16RB DRowell 2005 and newer - Bambi all models 1 10-01-2020 02:49 PM
