Old 05-18-2025, 05:11 PM   #1
2025 25' Trade Wind
Dennis , Massachusetts
Suburban IW60RL Water Heater
My new Tradewind Suburban water heater stopped firing up after sitting a month. The culprit was a tiny household spider that built his home in the Venturi vent located in the exhaust port of the water heater on the passenger side of the Airstream. A quick poke with a wire hanger dislodged the web and the unit fired right up! I wish I could say I thought of that first but neither tech support, Airstream, or a mobile RV repair man thought to look for a web first. Now that is part of my trip pre-flight!
Boale is offline   Reply With Quote
Old 05-20-2025, 04:44 PM   #2
2024 25' Trade Wind
Bothell , Washington
Thanks for the tip. Mine would not fire up the other day. Sounded like it was trying but never ignited. Propane was on but nada. Read online to do a complete reboot of the hot water system. Just turning it off doesn’t do it. Disconnected from shore and hit the battery disconnect switch. Waited a couple
If minutes and powered everything back up. Immediately started working. Just needed a reboot.
Chuck & Yvonne
2024 Trade Wind
2024 Rivian R1T
charlesk is offline   Reply With Quote
Old 05-21-2025, 06:10 AM   #3
2024 25' Trade Wind
Boulder , Colorado
My Tradewind's Suburban hot water heater stops working every 1-2 days. I reset it by pulling out fuse #5. It usually works again after I re-insert the fuse. It has been acting this way since I received my new Tradewind.
When I get a chance I'm going to have the dealer replace the hot water heater.
richh is offline   Reply With Quote
will my Bowen G6 10 heater door fit on a Suburban SAW6DE heater? DWG-77 Water Heaters, Filters & Pumps 0 05-22-2024 09:36 AM
Suburban IW60RL internal water damage apl Base Camp 0 05-17-2024 02:47 PM
Suburban Tankless water heater releasing water John1048 Sprinter and B-van Forum 0 05-09-2023 03:28 PM
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 07:17 AM
