Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 10-20-2019, 03:29 PM   #21
72 tradewind's Avatar
1972 25' Tradewind
Willis , Texas
Images: 8
Anode petcock comparison
to add to the debate-
the eaten anode came out of my lp gas only water heater, it is about a year old...
Name:	water heater anode.jpg
72 tradewind is offline   Reply With Quote
Old 10-21-2019, 09:10 AM   #22
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
The anode will dissolve regardless of if its doing anything "electrochemical" or not. If the water you put in is very soft ( or slightly acid ), they go pretty fast.
Petcock drain pouring water GypsyKarma Water Heaters, Filters & Pumps 11 10-10-2016 03:01 PM
Where is my fresh water tank petcock drain plug? '76 Tradewind Bobkatbry Fresh Water Systems 8 03-24-2016 03:56 PM
Newb: petcock to dump water not working? 3campers 1984-1988 Limited 4 06-09-2012 02:49 PM
Replacing Fresh Water Drain Petcock on 99 Safari Clawdan Fresh Water Systems 10 01-14-2010 04:15 PM
Metal Petcock Valve Replacement, Help! HowardD Fresh Water Systems 3 06-10-2005 09:41 PM
