Originally Posted by Hawk-ination
No offense to anyone but the plug is designed to blow out if there is a pressure problem. You should replace it with the correct plastic plug. We were told specifically not to use brass and especially not to use teflon tape.
If you are having leaking problems, replace it with a new plastic plug. Don’t modify to fix the leak. No one should risk having a mini bomb in their trailer or RV because if it can’t blow out through that hole, the pressure is going to go somewhere.
No offense, but isn't the water heater's pressure/temperature relief valve supposed to handle that?
Also to the original poster, as another commenter said drill a hole in the cap and insert a tool for removing broken-off sprinkler nipples.
