Old 01-10-2024, 10:20 AM   #1
2012 30' Flying Cloud
Tallahassee , Florida
Shower either too Hot or Too Cold
Anyone have a solution for too hot or too cold shower in a 2012 30' Flying Cloud? When I turn on the shower, the water is scalding hot but to get it to a tolerable level I have to turn the shower knob almost completely off which then kills the water pressure to barely running. Any thoughts on a solution?
klanemfsu is offline   Reply With Quote
Old 01-10-2024, 10:40 AM   #2
InsideOut's Avatar
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen , Colorado
Images: 108
Sounds like you may need a new mixit valve...yours might be sticking.
Shari
RMVAC | ACI - CO Unit (Formerly WBCCI) | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 01-10-2024, 11:01 AM   #3
Shari
Thank you.
Old 01-10-2024, 03:01 PM   #4
Mollysdad's Avatar
The water heaters provide water at scalding temps, I think 160º.
To make it tolerable, there's a bypass valve that adds cold water.
Make sure your valve is open.
Old 01-11-2024, 11:43 AM   #5
1960 26' Overlander
Tipton , Iowa
Like what was stated earlier, try the mix valve. You may also try setting your hot water heater to a cooler temperature.
Scott S is offline   Reply With Quote
Old 01-11-2024, 12:00 PM   #6
1988 32' Excella
Robbinsville , New Jersey
Those water heaters do not have adjustable thermostats.
Cold, Hot, Cold, Hot, Cold Hot thiel Water Heaters, Filters & Pumps 5 07-15-2023 12:12 AM
Either the AS is too big or the TV is too small Jim Lee On The Road... 18 12-07-2014 08:21 AM
Heat Pump - How cold its too cold? VeggieBullet Furnaces, Heaters, Fireplaces & Air Conditioning 7 01-09-2014 06:03 PM
